144 inch lbs is how many ft lbs? #358558
06/26/09 01:53 PM
06/26/09 01:53 PM
NE Ohio
71 FJ6 Charger Offline OP
NE Ohio
All I have is a ft lb torque wrench. Yes I know,I'm a retard!
'71 383HP FJ6 Charger SE
Re: 144 inch lbs is how many ft lbs? [Re: 71 FJ6 Charger] #358559
06/26/09 01:56 PM
06/26/09 01:56 PM
Eagle, Idaho
Neil Offline
The Doctor is in.
Neil  Offline
The Doctor is in.
Eagle, Idaho
12 inch pounds in a foot pound so 144 divided by 12 = 12 foot pounds.
Re: 144 inch lbs is how many ft lbs? [Re: 71 FJ6 Charger] #358560
06/26/09 02:00 PM
06/26/09 02:00 PM
So Cal
HealthServices Offline
Why would you even post that?
So Cal
I know you are but what an I?
Allen Here's a novel idea, let's not throw a bunch of parts at the car hoping it will fix the problem and instead spend a little time diagnosing it first. Life was a little easier when I was just a wrench.
Re: 144 inch lbs is how many ft lbs? [Re: HealthServices] #358561
06/26/09 02:22 PM
06/26/09 02:22 PM
Kent, Wa
340SHORTY Offline
Truck Nut
340SHORTY  Offline
Truck Nut
Kent, Wa
a Kalyfornian
I am truckless..
Re: 144 inch lbs is how many ft lbs? [Re: Neil] #358562
06/26/09 03:48 PM
06/26/09 03:48 PM
Texas, Dallas
G_T Offline
G_T  Offline
Texas, Dallas
Correct. See: http://www.srtorque.com/torqcon/tcip.html
1970 Charger - V10, 6spd, Alterkation, Street Lynx 4 Link, Moser Dana 60, Wilwood 14" disks, Forgeline 18" Wheels (Rear:335's), ISIS Multiplexing Wiring http://www.v10mopar.com 2012 Charger SRT8
Re: 144 inch lbs is how many ft lbs? [Re: 340SHORTY] #358563
06/26/09 03:48 PM
06/26/09 03:48 PM
Chino Valley
RodStRace Offline
RodStRace  Offline
Chino Valley
BTW, if you are using a 100 ft. lb. torque wrench, it won't be very accurate down there at 12 ft. lbs. That's just over 10 percent of the rating, and they work best (most accurate) in the middle to high range.
Re: 144 inch lbs is how many ft lbs? [Re: 71 FJ6 Charger] #358564
06/26/09 04:51 PM
06/26/09 04:51 PM
AndyF Offline
AndyF  Offline
Once you know how many inches are in a foot you can do the conversion.
Re: 144 inch lbs is how many ft lbs? [Re: AndyF] #358565
06/26/09 05:13 PM
06/26/09 05:13 PM
scratchnfotraction Offline
torquing mag intake bolts?
72 inch pounds first = 6 foot ponnds
then 144 inch pounds = 12 foot pounds
I try to use a 3/8 drive torque wrench when down to that low of a #
Re: 144 inch lbs is how many ft lbs? [Re: scratchnfotraction] #358566
06/27/09 03:30 PM
06/27/09 03:30 PM
ILLINOIS
V
volaredon Offline
volaredon  Offline
V
ILLINOIS
also with the part about the ft lb version not being accurate in those ranges.
Re: 144 inch lbs is how many ft lbs? [Re: volaredon] #358567
06/27/09 05:15 PM
06/27/09 05:15 PM
Florida STAYcation
dOrk ! Offline
The village idiot's idiot
dOrk !  Offline
Florida STAYcation
THIS is why they have those little dinky 3/8 and 1/4 drive "beam" T-wrenches ...with that "inch" scale on it.
Re: 144 inch lbs is how many ft lbs? [Re: AndyF] #358568
06/27/09 06:31 PM
06/27/09 06:31 PM
Renton, Wa.
Classof70Chally Offline
super gas
super gas
Renton, Wa.
There-in lies the problem !
