70 chall won't start #358154
06/25/09 11:41 PM
06/25/09 11:41 PM
MN
dodgebro Offline OP
dodgebro  Offline OP
MN
70 chall, starter clicks. When I jump, it starts. Replaced the battery, same. Replaced the starter, same. Replaced the relay, same. Thoughts?
Re: 70 chall won't start [Re: dodgebro] #358155
06/25/09 11:45 PM
06/25/09 11:45 PM
MN
dodgebro Offline OP
dodgebro  Offline OP
MN
Also, won't start with a charger, jump from another vehicle, no problem.
Re: 70 chall won't start [Re: dodgebro] #358156
06/25/09 11:48 PM
06/25/09 11:48 PM
Rust Belt, SW PA
Silver70 Offline
Silver70  Offline
Rust Belt, SW PA
I'd make sure you have a good ground.
68 Road Runner, 69 Belvedere, 71 Challenger Vert
340 barracuda, 01 Ram CTD, 95 Ram, 04 Ram, 85 Daytona turbo Z
66 GTO, 06 Magnum RT AWD. 07 Ram CTD, 07 Ram
Re: 70 chall won't start [Re: Silver70] #358157
06/25/09 11:54 PM
06/25/09 11:54 PM
MN
dodgebro Offline OP
dodgebro  Offline OP
MN
Did. I have good connection to everything. I am thinking broken wire in sol wire?
Re: 70 chall won't start [Re: dodgebro] #358158
06/26/09 08:16 AM
06/26/09 08:16 AM
Thoughts?
Jump the "G" male terminal on the starter relay to ground & retry
