edelbrock 1406 600 carb pops when I give it quick gas #358041
06/25/09 10:12 PM
06/25/09 10:12 PM
440dustr Offline OP
440dustr  Offline OP
edelbrock 600
I have 6lbs going to it now
it starts right up idles good and runs good but if I give it quick gas it pops, but if I give it gas gradually then it revs up no problem
I am assuming I just need to tune it up. Any particular steps to adjusting the air mixure. or should I check anything else
timing is on the money.
thanks
Re: edelbrock 1406 600 carb pops when I give it quick gas [Re: 440dustr] #358042
06/25/09 10:38 PM
06/25/09 10:38 PM
This is fully warmed up w the choke off?. check the accel pump squirt
Re: edelbrock 1406 600 carb pops when I give it quick gas [Re: 440dustr] #358043
06/25/09 10:57 PM
06/25/09 10:57 PM
Milwaukee, WI
In_The_Pink Offline
In_The_Pink  Offline
Milwaukee, WI
Do you have the Edelbrock Performer Series Carb Owner's Manual? It's very helpful. My 1406 was two steps rich out of the box (on my mild 360). I've found the electric choke needs to be fine tuned on these carbs, too.
Also, Edelbrock suggests you set the fuel pressure regulator at 5.5 psi, and have no more than 6psi at idle and no less than 2psi at WOT.
Re: edelbrock 1406 600 carb pops when I give it quick gas [Re: In_The_Pink] #358044
06/25/09 11:23 PM
06/25/09 11:23 PM
I thought these carbs were factory jetted lean which if so would make it more likely to hesitate if any system isn't right
Re: edelbrock 1406 600 carb pops when I give it quick gas [Re: RapidRobert] #358045
06/26/09 01:16 AM
06/26/09 01:16 AM
Missouri
MY340 Offline
MY340  Offline
Missouri
Too much accelerator pump shot can cause your problem. If you have the linkage in the top hole of the arm go to the middle hole and see if it helps.
1970 FE5 Duster 360/904/3.91's SOLD 1973 TB3 SpaceDuster 340/4spd/4.10's SOLD Moparless for now but when the opportunity is right I'll have another one.
Re: edelbrock 1406 600 carb pops when I give it quick gas [Re: 440dustr] #358046
06/26/09 01:48 AM
06/26/09 01:48 AM
Gainesville,FL
goldmember Offline
goldmember  Offline
Gainesville,FL
It's going lean and if it drives well under light throttle and cruise I'd start by increasing the pump shot. You may also need to make slight changes to the metering rods,jets and step up springs.This assumes the timing is OK and the idle mixture is adjusted.
Re: edelbrock 1406 600 carb pops when I give it quick gas [Re: 440dustr] #358047
06/26/09 02:24 AM
06/26/09 02:24 AM
Someplace you aren't
SomeCarGuy Offline
SomeCarGuy  Offline
Is it new? Maybe has a bad accel pump if it is old.
I want my fair share
