Radiator clamp ?
#357894
06/25/09 06:36 PM
06/25/09 06:36 PM
Posts: 733 Long Island NY
yellow sixpack
Long Island NY
Thinking about putting the Corbin style radiator clamps on my car. I know the alligator style are the better way to go. Looking for Pros and Cons. Thanks in advance. Rob
If you can't be smart.....don't be stupid!
Re: Radiator clamp ?
[Re: yellow sixpack]
#357897
06/25/09 07:11 PM
06/25/09 07:11 PM
Posts: 1,109 Hiram, Georgia
474218
Hiram, Georgia
When I bought my new 69 RR, the first thing I did was clean off all those silly grease pencel marks. The second was put on proper radiator clamps in place of the flimsy factory jobs.
[Re: FJ5_Fish]
#357901
06/25/09 09:57 PM
06/25/09 09:57 PM
Posts: 4,231 State of retirement
52savoy
State of retirement
I always use the factory clamps but have noticed they are different. I can't put my finger on it but I think the guage is a hair thinner. I have had leak problems in the last 2 years I have never had before. I had a lower hose blow right off the rad outlet with an NOS hose. Another problem is the hoses (all the hoses) are a thinner wall - The I.D. is right but the thinner wall thickness makes for a smaller O.D. which does not give the clamp enough meat to bite around. I put an original clamp on that lower hose and all is good. I think we have to start using clamps 1 size smaller than normal to compensate for the reduction in hose O.D. and for the (seemingly) reduced tension/guage - whatever the problem is with these new clamps. I had the heater hoses and the by-pass hose (smallblock) leak with these newer hoses/clamps. And- if I don't have NOS I use the best hoses I can get with the same issues.
That's what I noticed too. Don't through any original clamps away just replate or paint them. I've (sometimes)found that a leaking clamp can be stopped by shifting the clamp on the hose.
[Re: FJ5_Fish]
#357902
06/25/09 09:59 PM
06/25/09 09:59 PM
Posts: 18,157 Mass
DAYCLONA
Mass
I been using the repro clamp kits, original corbin clamps, NOS, or reconditioned,......newer hoses, even repro hoses are thinner, hence the clamps won't seal properly,....squeezeing the clamp to be "tighter" dosen't work, it only causes the clamp to "egg" in shape, and thus squeezes on the sides only, causing a leak,....I've found that purchaseing the clamps directly thru the manufacturers, I can purchase them in 1/16-1/8 inch increments to the sizes I really need for a tight fit,.....
[Re: DAYCLONA]
#357908
06/26/09 10:46 AM
06/26/09 10:46 AM
Posts: 2,808 Wisconsin
wkroncke17
Wisconsin
Mike, where do you order the custom size clamps directly from? What is the correct diameter? I like the spring clamps because they always give constant tension, where the screw type ones they get tightened to a certain point only.
