Re: 1990 dakots 5 speed questions
[Re: bohmer2]
#357699
07/27/09 12:48 AM
07/27/09 12:48 AM
Posts: 7,992 Escondido, CA. Ron Podsiadly,...
Mopar Ron
Thanks Greg, that is exactly the link I was remembering.
Second Ron, I think it is the magnum bellhousing from the gen II dakota's is the one that connects to all the LA, magnum, and even the new hemi small block motors as well as the v-6 magnums.
Thanks, just my luck, I have the one no one needs Ron....
[Re: dartracer]
#357700
07/28/09 01:11 AM
07/28/09 01:11 AM
Posts: 1,757 levittown pa
fstfish66
levittown pa
some where along the line they changed how the dakota tranny bolts to the bell,,,it use to be like a normal set up we all have seen before,,then they changed it to bolting in from inside the bell housing,,
and about the supra tranny,,a company that chrysler had ownership once upon a time called new process they make a ton of trannys for lots of companies,,so maybe the toyota/dakota bolt pattern was just because..
1966 barracuda prostreeter super charged 340(SOLD) 1940 dodge coupe 241 hemi street rod 2014 ram express hemi 4x4 dailey driver 2015 cherokee 2013 R/T classic
[Re: bohmer2]
#357701
07/29/09 12:03 PM
07/29/09 12:03 PM
Posts: 16,123 Grand Haven, MI
patrick
Grand Haven, MI
the "la" style 3.9 has the same bolt pattern.
somewhere ~96 or so the dakota switched from the Aisin sourced AX15 tranny (cousin to the supra's R154 tranny) to the NVG 1500's (4 banger) and 3500's (V6/V8). the 3500's have an integral bellhousing, like a 727/904.
