1990 dakots 5 speed questions #357679
06/25/09 02:23 PM
06/25/09 02:23 PM
n.e. pa.
65rbdodge Offline OP
n.e. pa.
i want to bolt this trans behind my 318. after some research i found i will need the flywheel from the donor truck, and it uses a different clutch than the 10.5" 833. it uses the same pilot bushing PN as the 833 so i guess bolting it up wont be a problem. does anyone know if a 727/4 speed or 904/3 speed slip yoke will fit this trans?
the 318 is just a stock rebuild w/ 340 cam, windage tray, perf. intake and holley 450 so im not making a ton of HP i think this trans should hold up behind it. what do you think? going in my 47 desoto.
Re: 1990 dakots 5 speed questions [Re: 65rbdodge] #357680
06/25/09 03:36 PM
06/25/09 03:36 PM
Iowa
76dodgeboy Offline
76dodgeboy  Offline
Iowa
727 is a 3spd auto
Re: 1990 dakots 5 speed questions [Re: 76dodgeboy] #357681
06/25/09 04:15 PM
06/25/09 04:15 PM
Chino Valley
RodStRace Offline
RodStRace  Offline
Chino Valley
He's asking about a shared slip yoke.
I'd say that if you are grabbing the transmission, flywheel and clutch parts (cores),
go ahead and grab the driveshaft too. That way you KNOW the slip yoke fits.
If you can, figure out the throw of the clutch before tearing it apart. If you are going with mechanical, it will be needed. If you are going hydraulic, you will know when it's right.
Re: 1990 dakots 5 speed questions [Re: RodStRace] #357682
06/25/09 04:53 PM
06/25/09 04:53 PM
Iowa
76dodgeboy Offline
76dodgeboy  Offline
Iowa
I know I was just correcting him on the 727
Re: 1990 dakots 5 speed questions [Re: 76dodgeboy] #357683
06/25/09 11:07 PM
06/25/09 11:07 PM
Chino Valley
RodStRace Offline
RodStRace  Offline
Chino Valley
Dude, he said this " 727/4 speed or 904/3 speed slip yoke "
What he meant was there is one size that fits a 727 torqueflite 3 speed automatic transmission AND a 4 speed manual transmission.
There is another size that fits the 904 automatic 3 speed transmission and a 3 speed manual transmission. Get it?
Re: 1990 dakots 5 speed questions [Re: RodStRace] #357684
06/26/09 11:47 AM
06/26/09 11:47 AM
Tracy CA
rabid scott Offline
"You're Where?"
rabid scott  Offline
"You're Where?"
Tracy CA
To complicate matters more, some 3 speed manual trannies share the larger 727/4 speed slip yoke....
I had a '68 Valiant I swapped from a 3 speed manual on the column to a OD four on the floor and didn't have to change the driveshaft at all.
Re: 1990 dakots 5 speed questions [Re: RodStRace] #357685
06/26/09 12:33 PM
06/26/09 12:33 PM
Iowa
76dodgeboy Offline
76dodgeboy  Offline
Iowa
Oh Didnt know that . Good to know know
Re: 1990 dakots 5 speed questions [Re: RodStRace] #357686
06/26/09 12:52 PM
06/26/09 12:52 PM
n.e. pa.
n.e. pa.
yup, thats what i meant. i didn`t check to see if the driveshaft is useable yet. usually they are bent because the pick cars/truck with the forks on the bucket loader. maybe i`ll just get the slip yoke and get a new shaft made if i have to.
Re: 1990 dakots 5 speed questions [Re: 65rbdodge] #357687
06/27/09 09:02 PM
06/27/09 09:02 PM
up yours
Supercuda Offline
About to go away
Supercuda  Offline
About to go away
up yours
To reall mess things up there as a few A833's that use the small 904 style yoke.
In any case, I ran the Dak V6 flywheel on my LA engine when I converted to four speed. So it should work for you.
Don't be the exception.
Re: 1990 dakots 5 speed questions [Re: Supercuda] #357688
06/30/09 02:37 AM
06/30/09 02:37 AM
levittown pa
fstfish66 Offline
fstfish66  Offline
levittown pa
im pretty sure the v6 and 318 magnums are internaly balanced like a LA 318/340 or a 361/383/440/413 the 360s of all vintages are balanced externally and all are balanced differently,,,the V6 and 318 dakota 5 speed fly wheel wil work on your LA 318..but dont do any speed shifting or ram rodding that tranny,,its not an 833...but will be fun in a normaly driven street rod and the O,D will be great,,
if you get the brake/clutch pedal assembly out of the dakota you will se how simple it is to use all the dakota hyd throw out bearing stuff,,the clutch master cylinder mounts to the pedal assembly,,run the line to the bearing and you are done,,,simplest mopar conversion,,ever,,
1966 barracuda prostreeter super charged 340(SOLD)
1940 dodge coupe 241 hemi street rod
2014 ram express hemi 4x4 dailey driver
2015 cherokee
2013 R/T classic
Re: 1990 dakots 5 speed questions [Re: rabid scott] #357689
06/30/09 02:58 AM
06/30/09 02:58 AM
Sorrento, BC, Canada
4speeds4me Offline
4speeds4me  Offline
And while we're complicating matters, remember that some A/F-body 833OD's used the 904 yoke. Go figure!
2 Demons...no, not my kids!
Re: 1990 dakots 5 speed questions [Re: 65rbdodge] #357690
07/24/09 07:20 PM
07/24/09 07:20 PM
New Richmond, WI
K
kams Offline
kams  Offline
K
New Richmond, WI
the slip yoke is a 904 style and the trans will hold up because is I had a 88 dakot with 4 cyl. 5speed thet I put a mild built 318 behind and beat the crap out of, race shifting 4 grand drops, etc, and you can usethe 833 style clutch parts i did.
Re: 1990 dakots 5 speed questions [Re: kams] #357691
07/25/09 01:05 PM
07/25/09 01:05 PM
Strasburg CO.
dartracer Offline
dartracer  Offline
Strasburg CO.
So you are saying that the early 2.5 4cyl has the same bellhousing bolt pattern as a small block?
Re: 1990 dakots 5 speed questions [Re: dartracer] #357692
07/25/09 02:16 PM
07/25/09 02:16 PM
MA
Greg55_99 Offline
Greg55_99  Offline
MA
No it does not. The 3.9 has the same pattern as the Mopar Small Block. The pre 96 2.5L has the 2.2L K car four banger bolt pattern.
Greg
Re: 1990 dakots 5 speed questions [Re: Greg55_99] #357693
07/25/09 10:33 PM
07/25/09 10:33 PM
Strasburg CO.
dartracer Offline
dartracer  Offline
Strasburg CO.
I thought the Dakota 5spd trany and bellhousing was all one piece.
Re: 1990 dakots 5 speed questions [Re: dartracer] #357694
07/25/09 11:43 PM
07/25/09 11:43 PM
Chino Valley
RodStRace Offline
RodStRace  Offline
Chino Valley
I found an interesting thread this afternoon, but can't find it now. Mentioned all the trans that can be swapped using the Dakota bellhousing, including a (gasp) Toyota Supra trans. It even had a reference to a thread here.
Here's another
http://www.hotrodders.com/forum/toyota-5-speed-10418.html?highlight=dakota+transmission+supra
Re: 1990 dakots 5 speed questions [Re: RodStRace] #357695
07/26/09 09:31 AM
07/26/09 09:31 AM
Thayer, MO
bohmer2 Offline
bohmer2  Offline
Thayer, MO
I had a link at one point in time to a 4X4 website that had a ton of information on manual trans swaps including a lot of details on the supra and dakota transmissions. I will dig for the link and post it up when I find it. As I recall the Supra trans was surprisingly strong for what it came from.
Re: 1990 dakots 5 speed questions [Re: bohmer2] #357696
07/26/09 11:41 AM
07/26/09 11:41 AM
MA
Greg55_99 Offline
Greg55_99  Offline
MA
Re: 1990 dakots 5 speed questions [Re: Greg55_99] #357697
07/26/09 12:31 PM
07/26/09 12:31 PM
Escondido, CA. Ron Podsiadly,...
Mopar Ron Offline
Mopar Ron  Offline
so guys I have a 1987 Dakota V6 bell housing and 5 sped trans here, is "THAT" the bellhousing that people want to use? if so what is the going price for one of these??? thanks Ron...
Re: 1990 dakots 5 speed questions [Re: Mopar Ron] #357698
07/26/09 11:04 PM
07/26/09 11:04 PM
Thayer, MO
bohmer2 Offline
bohmer2  Offline
Thayer, MO
Thanks Greg, that is exactly the link I was remembering.
Second Ron, I think it is the magnum bellhousing from the gen II dakota's is the one that connects to all the LA, magnum, and even the new hemi small block motors as well as the v-6 magnums.
