Trans brake switch wiring HELP! #357664
06/25/09 01:28 PM
06/25/09 01:28 PM
Tampa Florida
dc426 Offline OP
gotta keep'm separated
dc426  Offline OP
Tampa Florida
I recently bought a Biondo Double-O T-brake switch. it didn't come with wiring instructions and the web site has nothing either. The switch has 3 terminals. 1 marked (1com), one in the middle marked (3 NO) and the one on the right marked (2 NC). Question is which ones do the hot lead, T-brake and 2 step go to? Or does it matter?
Here's a pic.
DC
Re: Trans brake switch wiring HELP! [Re: dc426] #357665
06/25/09 01:39 PM
06/25/09 01:39 PM
MR_P_BODY Offline
MR_P_BODY  Offline
The NO is normally open, NC is normally closed, you
can run either way through the switch but if you run
the hot to the #1 then hook the output to the NO it
will work when you press the button.... hook the 2 step
lead to the NO, that way it will work when you press
the button
Re: Trans brake switch wiring HELP! [Re: MR_P_BODY] #357666
06/25/09 01:44 PM
06/25/09 01:44 PM
Tampa Florida
dc426 Offline OP
dc426  Offline OP
Tampa Florida
excellent! Thanks
DC
