Hole in gas tank repair....
#357546
06/25/09 11:08 AM
06/25/09 11:08 AM
Posts: 1,506 Indiana
GrnMagic77
Peter Parker
Peter Parker
Indiana
Anyone know the best way to repair a small rust hole about 1/16 to 1/8" round ? I have seen some repair kits in the NAPA catalog but don't know anyone who has actually used them.
Obviously welding may not be a very good ideal so I'm told.Even though the tank has sat dry for about 8yrs it still has a bit of residue from the layer of rust.I have cleaned it out as much as possible and for as small as the hole is,a repair kit just might do the trick.
Any suggestions...aside from buying a new tank ??
1978 Round Up-1977 Warlock-1977 Powerwagon Adven.-
1976 Blue "Macho"-1974 Charger-1968 Fury III -1966 Newport *
Re: Hole in gas tank repair....
[Re: GrnMagic77]
#357547
06/25/09 11:17 AM
06/25/09 11:17 AM
Posts: 21,074 Niles , Ohio
therocks
Niles , Ohio
I fixed the kids in his Buick after it was stolen.I cleaned it got JB weld and a screw that fit.JB the screw and install.Then let it dry a thin piece of metal and JB over it.Its been almost a year and dry as a bone.Oh its at the bottom of the tank.Rocky
Chrysler Firepower
[Re: GrnMagic77]
#357550
06/25/09 11:28 AM
06/25/09 11:28 AM
therocks
Niles , Ohio
Like I said his is at the bottom near the elec pump.JB the screw dry the a thin small piece of metal with more JB.A year and its still dry.Used tank was 75 bucks and he had no $$$.Rocky
Chrysler Firepower
[Re: stubbs300 ]
#357555
06/25/09 06:40 PM
06/25/09 06:40 PM
Posts: 733 Long Island NY
yellow sixpack
Long Island NY
Gas tanks pretty cheap these days. Somebody selling new Ebodys ones on E..y for $160 buy it now.
If you can't be smart.....don't be stupid!
[Re: yellow sixpack]
#357556
06/25/09 07:29 PM
06/25/09 07:29 PM
Posts: 565 IA
landon1
IA
i never tried jb weld, but i had tried the epoxy from the parts store several times on my tank...eventually would start leaking again....bought a new tank for ~$200 4 years ago.
'71 Satellite Sebring 440
#357557
06/25/09 08:21 PM
06/25/09 08:21 PM
Challenger 1
Cincinnati, Ohio
If the hole is from rust, then there are other areas that are thin too. God help your fuel pump, buy a new tank. I'm telling you that's the way to go, replace it.
[Re: MoreParts]
#357558
06/25/09 09:59 PM
06/25/09 09:59 PM
Posts: 5,314 Carstairs, Alberta, Canada
dave571
I've got some JB weld holding a crack in mine for over 5 years now. Just drain it, slap it on, and let it dry.
Jb is pretty amazing stuff.
In fact, I fixed some pinholes in a used tank I had installed as an auxiliary tank in a motor home I owned.
Of course I found the holes, after I filled it.
4 holes. 4 sheet metal screws with jb weld on them, ran in while it was STILL DRIPPING fuel
It stopped immediately. I would like to testify as to how long it held, but I sold the mh the following year.
[Re: maximus]
#357560
06/26/09 08:41 PM
06/26/09 08:41 PM
Posts: 2,734 Charlotte, NC
446acuda
Charlotte, NC
Most auto parts suppliers sell a two part epoxy stick that is designed to fix gas tanks. You twist together and stick in the hole, I have fixed two gas tanks with this and it worked both times. One of of repairs was done in freezing tempature and it worked. It only cost about $3.00 for the epoxy stick.
I've used this stuff. Tank doesn't need to be dry or empty. Wipe off the leak and immediately put the epoxy on it. Don't mess around with the epoxy too much after you put it on since that will cause it to seep around the epoxy. Then you will have to start over.
