Re: 22 vs 26 inch rad support opening.
[Re: Vert]
#357233
06/24/09 11:34 PM
06/24/09 11:34 PM
Posts: 1,522 Orleans, Ontario
moparcanuk
Orleans, Ontario
Is the LH/Driver Sside constant and the RH/Pass side what varies between 22 and 26 inch rad supports on E and B bodies? Thanks!
I think this is correct.
[Re: moparcanuk]
#357234
06/25/09 12:25 AM
06/25/09 12:25 AM
Posts: 2,431 SK,Canada
gregsrt
SK,Canada
My 69 Satellite has a 22" opening and I picked up 26" side panels on Ebay and both sides are different than the 22" opening
An association of men who will not quarrel with one another is a thing which has never yet existed, from the greatest confederacy of nations down to a town meeting or a vestry.
Thomas Jefferson
[Re: Vert]
#357235
06/25/09 08:25 AM
06/25/09 08:25 AM
Posts: 75,070 U.S.S.A.
JohnRR
U.S.S.A.
what year B body ?
I have no idea on the E body but the 69 parts manual shows a different part number for the left side for the 26" vs the 22" , what is different ?? People have said they just installed the right side and it worked , or modded the right side after bolting the rad to the left and the fan didn't hit the shroud so ????
[Re: Vert]
#357240
06/25/09 02:05 PM
06/25/09 02:05 PM
Posts: 5,138 East Aurora (Buffalo) NY
RoadRunner
For an E-body, both sides are different. However, the drivers side is just about 1/2" off. I think if you replace the PS side, the slots int he radiator will probably allow you to mount it. I have pics somewhere showing the difference on the DS.
68 Road Runner (383/4speed, post car w/decor pkg) - Major Project 69 Road Runner w/472 Hemi & 4 speed. 70 Challenger R/T SE EF8 w/ V9J, U - A32 - Major Project 2023 Ford Mach 1
[Re: RoadRunner]
#357241
06/25/09 07:09 PM
06/25/09 07:09 PM
Posts: 1,756 London, England
Gavin
London, England
E-Body the pass side is quite different, the drivers side only a little bit. I also fitted the 26" in my 22" gap. with some care it works fine (couple of pics of mine in my buildup post)
[Re: drmonday]
#357247
06/26/09 08:53 AM
06/26/09 08:53 AM
Posts: 4,742 Florida
BDW
I also did the same thing (put a 26 inch rad in a 22 inch opening). Works great, unless you point it out to someone its unnoticeable. I don't think its worth the effort to replace the both panels.
Same here
Looks like you've been thinking about this awhile
https://board.moparts.org/ubbthreads/show...rue#Post5258536
[Re: NITROUSN]
#357250
06/26/09 06:49 PM
06/26/09 06:49 PM
Posts: 2,489 Tracy, New Brunswick, Canada
magnumcharger
what year B body ?
On the b-body with a 26 core both the left and right are different than the 22 inch. These pictures were sent to me from a fine Canadian mopar nut.
OH! So now I'm a nut!!!
