340 six pack linkage question? #357199
06/24/09 10:12 PM
06/24/09 10:12 PM
New York
rarefish Online content OP
rarefish  Online Content OP
New York
I just reinstalled my carbs after a rebuild and I went to reattach the linkage that connects the outboard carbs the the center one. It seems like something is missing where the linkage goes into the crescent shaped slot on the center carb. Check out the picture. There is a small nylon ring behind the cotter pin that seems to be too loose. Any ideas?
Re: 340 six pack linkage question? [Re: rarefish] #357200
06/24/09 11:13 PM
06/24/09 11:13 PM
the boonies
aarcuda Offline
aarcuda  Offline
the boonies
there is a sleeve with a lip on it that goes in the slot on the center carb. i think i see the rim of it under the lip of the stud there- the second washer looking thingie from the top.
i'd have to go out to the shop to make sure what mine looks like. take a picture of all the parts disassembled and i can tell better
Re: 340 six pack linkage question? [Re: aarcuda] #357201
06/25/09 09:49 PM
06/25/09 09:49 PM
New York
New York
Does anyone have a picture of what the linkage should look like??
Re: 340 six pack linkage question? [Re: rarefish] #357202
06/29/09 11:31 AM
06/29/09 11:31 AM
NEW JERSEY
AARCONV Offline
AARCONV  Offline
NEW JERSEY
the way u have it there is like mine except the nylon thing that does not belong..
my setup is as follows
stud through the carb linkage
flat washer
front rod
rear rod
flat washer
cotter pin
same as yours...lose the nylon thing
hope this helps...can't get a close up picture clear as yours
