Aluminum crankshaft pulley #356832
06/24/09 05:16 PM
06/24/09 05:16 PM
Manitoba, Canada
Big Wedge Offline OP
Manitoba, Canada
I am looking for a stock diameter (6.5" OD) crankshaft v-belt pulley for my 440 engine. It has to have the shorter hub for a Fluidamper dampner. Does anyone make this?
Garth
Re: Aluminum crankshaft pulley [Re: Big Wedge] #356833
06/24/09 07:12 PM
06/24/09 07:12 PM
Warren, MI
Jerry Offline
Jerry  Offline
Warren, MI
i can make one if you can't find anything off the shelf.
Superior Design Concepts
2574 Elliott Dr
Troy MI 48083
jerry@sdconcepts.com
www.sdconcepts.com
Facebook page: Superior Design Concepts
www.bcrproducts.com
Re: Aluminum crankshaft pulley [Re: Jerry] #356834
06/24/09 08:37 PM
06/24/09 08:37 PM
PA
70HemiGTX Offline
70HemiGTX  Offline
PA
Call March. They should have one for you.
Re: Aluminum crankshaft pulley [Re: 70HemiGTX] #356835
06/25/09 07:23 AM
06/25/09 07:23 AM
Manitoba, Canada
Manitoba, Canada
Thanks, but I called March and they only make an under drive (5.25") pulley for the crank.
Garth
Re: Aluminum crankshaft pulley [Re: Big Wedge] #356836
06/25/09 10:22 AM
06/25/09 10:22 AM
PA
70HemiGTX Offline
70HemiGTX  Offline
PA
Garth
Well that's news to me because I have one on my car. Here's the part #: 10009 But.......
Now that I think about it that may actually be for a regular balancer because I have a spacer behind my water pump pulley.
Re: Aluminum crankshaft pulley [Re: 70HemiGTX] #356837
06/25/09 04:50 PM
06/25/09 04:50 PM
Manitoba, Canada
Manitoba, Canada
Thanks Ted, I will give them a call.
Tom, that is the pulley I have now. It is an underdrive pulley to go with a Fluidamper. That is why you need the spacer.
Garth
Re: Aluminum crankshaft pulley [Re: Jerry] #356838
06/25/09 05:07 PM
06/25/09 05:07 PM
Florida STAYcation
dOoC Offline
The village idiot's idiot
dOoC  Offline
Florida STAYcation
I need one for a V-drive boat project. But a dual "pattern" ... one slot for the water-pump(very small) .... and the other for driving the alternator.
