THE FIRST HEMI BLOCK ?? #356776
06/24/09 04:35 PM
06/24/09 04:35 PM
StewartP Offline OP
Mopar Vintage Picture Guy
StewartP  Offline OP
THE FIRST 426 HEMI BLOCK ?
This is strictly conjecture, but it does warrant investigation. I saw this block again today, it has been cleaned up.
As the tale goes, there were a small number of 426 Hemi blocks cast for the 64 Daytona 500. The castings were generally very poor and they had numerous issues, not the least was cracking and water leaks. As a result, engineers and casting experts went to the foundry and hand massaged the cores to address those issues. The rest is history, as the Hemi dominated the Daytona 500 that year. It was thought that the original 10 or 12 blocks were scrapped or used for “no load” in-house testing
1. Shows the part number and casting date 2468330-1 and 10-17-63
2. Shows lettering on the front of the block, that I think was used on MW blocks - it is my understanding that the Hemi was a re-do of the MW block.
3. Lettering and numbers on the front pad
A864 EXO
1356
My understanding is that A864 was the code for the NASCAR HEMI program.
On that same line is EXO - my guess is that EX means experimental and my understanding is that test motors were numbered starting at “0"
My other deduction is that the number below that (1356) refers to building 135 - dyno cell 6
Does this prove that this is the FIRST HEMI - that is not for me to say but does anyone have any input as to this hypothesis ?
Stewart
Re: THE FIRST HEMI BLOCK ?? [Re: StewartP] #356777
06/24/09 04:36 PM
06/24/09 04:36 PM
StewartP Offline OP
StewartP  Offline OP
2
Re: THE FIRST HEMI BLOCK ?? [Re: StewartP] #356778
06/24/09 04:36 PM
06/24/09 04:36 PM
StewartP Offline OP
StewartP  Offline OP
3
Re: THE FIRST HEMI BLOCK ?? [Re: StewartP] #356779
06/24/09 04:42 PM
06/24/09 04:42 PM
StewartP Offline OP
StewartP  Offline OP
If anyone is interested, I have the full size photos (about 15) and will be glad to send them to you.
StewartP
Re: THE FIRST HEMI BLOCK ?? [Re: StewartP] #356780
06/24/09 04:58 PM
06/24/09 04:58 PM
yarnell,az
mopacltd Offline
mopacltd  Offline
yarnell,az
Are you the proud owner of this block, Stewart?
Re: THE FIRST HEMI BLOCK ?? [Re: mopacltd] #356781
06/24/09 05:11 PM
06/24/09 05:11 PM
ohio
HEMIDARTS Offline
HEMIDARTS  Offline
ohio
Re: THE FIRST HEMI BLOCK ?? [Re: mopacltd] #356782
06/24/09 05:23 PM
06/24/09 05:23 PM
StewartP Offline OP
StewartP  Offline OP
It is not my block, but I have visitation rights :-)
StewartP
Re: THE FIRST HEMI BLOCK ?? [Re: StewartP] #356783
06/24/09 06:01 PM
06/24/09 06:01 PM
Illinois
CRE2004 Offline
super gas
CRE2004  Offline
super gas
Illinois
By the looks of the plug in the side and the paint job, someone is planning on using it??
Re: THE FIRST HEMI BLOCK ?? [Re: CRE2004] #356784
06/24/09 06:49 PM
06/24/09 06:49 PM
StewartP Offline OP
StewartP  Offline OP
it had been used previously - it has 3 sleeves now and is 60 over - no use anymore - strictly a collectible - no way to really document its pedigree, but sure think it is the FIRST
StewartP
Re: THE FIRST HEMI BLOCK ?? [Re: StewartP] #356785
06/24/09 08:08 PM
06/24/09 08:08 PM
I want to see the first 2x4 that Petty used to stay in the seat at Daytona testing that year---I may have used it to get my mules attention and then I don't know what I did with it--
Re: THE FIRST HEMI BLOCK ?? [Re: StewartP] #356786
06/24/09 08:23 PM
06/24/09 08:23 PM
U.S.A.
Dartacus Offline
Dartacus  Offline
U.S.A.
If it were actually the first 426 Hemi block, I would think it would be very much a prized possession.
Post deleted by Defbob [Re: ] #356787
06/24/09 09:14 PM
06/24/09 09:14 PM
Re: THE FIRST HEMI BLOCK ?? #356788
06/24/09 10:19 PM
06/24/09 10:19 PM
A collage of whims
topside Offline
topside  Offline
A collage of whims
IF those stampings can be authenticated by someone who was there, wouldn't THAT be some sort of Holy Item...
Cross-bolted mains and head fastener bosses (obvious questions) in the valley?
Re: THE FIRST HEMI BLOCK ?? [Re: topside] #356789
06/24/09 11:52 PM
06/24/09 11:52 PM
DFW
mr_340 Offline
mr_340  Offline
DFW
I guess it would be hard to prove it was the FIRST block unless someone at the foundry or records of the first casting date, and how many were cast on that date? I think I heard the very first ones were scrapped, but maybe one of the first ones that worked.
Are we going to set up a shrine for it in Bradenton? Can I visit the Holy of Holies the next time I'm in Tampa? Does it reside in a golden engine crate with cherubs on each corner?
Floyd Lippencott IV
Re: THE FIRST HEMI BLOCK ?? [Re: mr_340] #356790
06/25/09 01:50 AM
06/25/09 01:50 AM
Spokane Washington
ScottSmith_Harms Offline
Mr Wizzard
Mr Wizzard
Spokane Washington
I agree, it certainly appears to be the real thing and likely one of the first Hemi blocks ever cast and used, but I don't see any way you could ever officially call it THE first. There were probably multiples cast, machined, build, shipped, and installed in race cars the very same day, if that were the case (which it likely was) which one of these would be called "the first"?
Cool block either way, would love to see many more pics showing the entire sides, etc.
Post deleted by Defbob [Re: ScottSmith_Harms] #356791
06/25/09 04:23 AM
06/25/09 04:23 AM
Re: THE FIRST HEMI BLOCK ?? #356792
06/25/09 04:54 AM
06/25/09 04:54 AM
Worst Weather USA
493_DART Offline
493_DART  Offline
Worst Weather USA
You would think with this crazy internet thing....that someone (even moparts) could get in contact with some of the guys from the Chrysler foundry from 63/64 to get some info...... any old Detroit guys on here that could ?
maybe it could get as mysterious as the max wedge head debate.....
Re: THE FIRST HEMI BLOCK ?? [Re: StewartP] #356793
06/25/09 07:38 AM
06/25/09 07:38 AM
StewartP Offline OP
StewartP  Offline OP
I should restate my theory - this might not be the FIRST HEMI block that was cast, but it might be the FIRST block that was used in some in-house testing - (as per the numbers and letters on the front pad, if they are legit) - Now how do I prove that ??
Re: THE FIRST HEMI BLOCK ?? [Re: StewartP] #356794
06/25/09 05:15 PM
06/25/09 05:15 PM
Park Forest, IL
slantzilla Offline
slantzilla  Offline
Park Forest, IL
Have Galen authenticate it.
Re: THE FIRST HEMI BLOCK ?? [Re: slantzilla] #356795
06/25/09 05:25 PM
06/25/09 05:25 PM
Baltimore/Denver
64Post Offline
64Post  Offline
Baltimore/Denver
With the state of the economy I'm sure that's po$$ible...
