Original Sheet Metal Gauge thickness? #356372
06/24/09 03:32 AM
06/24/09 03:32 AM
Utah
topbrent Offline OP
topbrent  Offline OP
Utah
What was the original thickness / gauge of metal for the various areas of 60's mopar?
Ie:
Front Fenders,
Quarter panels,
Trunk floor,
Floor pans,
Wheel Tubs.
This would be a good topic for the archives, as there seems to be alot of differing opinions.
Re: Original Sheet Metal Gauge thickness? [Re: topbrent] #356373
06/24/09 01:12 PM
06/24/09 01:12 PM
Kelowna, B.C. Canada
DPelletier Offline
DPelletier  Offline
Exterior panels were typically 22ga, but most people here will tell you it was thicker!
1970 Super Bee 440 Six Pack 1974 'Cuda 2008 Ram 3500 Diesel 2006 Ram 3500 Diesel 2004.5 Ram 2500 Diesel 2003 Ram 3500 Diesel 2006 Durango Limited [url] http://1970superbee.piczo.com [/url]
Re: Original Sheet Metal Gauge thickness? [Re: DPelletier] #356374
06/24/09 03:45 PM
06/24/09 03:45 PM
Houston Texas
PAINT IT BLACK Offline
Got a CHIP on my shoulder
Houston Texas
Does that include wheel housings?
Re: Original Sheet Metal Gauge thickness? [Re: PAINT IT BLACK] #356375
06/24/09 04:35 PM
06/24/09 04:35 PM
DPelletier Offline
DPelletier  Offline
Not sure on the wheel housings, Steve, they might have been thicker: I never mic'd any of those. My guess would be that they are thicker; probably 18 - 20ga.
Re: Original Sheet Metal Gauge thickness? [Re: DPelletier] #356376
06/24/09 06:22 PM
06/24/09 06:22 PM
Houston Texas
Houston Texas
Well I'll be sure and let ya know when I find out. Just thought I'd ask so I could procure material before the day I
Re: Original Sheet Metal Gauge thickness? [Re: PAINT IT BLACK] #356377
06/24/09 07:11 PM
06/24/09 07:11 PM
MO
P
psycho_440 Offline
psycho_440  Offline
P
MO
22 is very thin. if you are making patches i would go with at least 18. i think most late model stuff is 18
Re: Original Sheet Metal Gauge thickness? [Re: psycho_440] #356378
06/24/09 07:33 PM
06/24/09 07:33 PM
Lost and Spaced
bboogieart Offline
bboogieart  Offline
Lost and Spaced
I think he's working on the radiator core support, judging by the earlier post.
Maybe you can borrow a mic and measure to make sure and get it right the first time.
Re: Original Sheet Metal Gauge thickness? [Re: topbrent] #356379
06/24/09 08:55 PM
06/24/09 08:55 PM
Tampa , Fl
MoparJoe Offline
super gas
MoparJoe  Offline
super gas
Tampa , Fl
On a Dart the 1/4's & outer wheelhouses are 20ga, trunk floor and fenders are 22ga, not sure on the floors since my '68 didn't have any left but the replacement panels were thinner than 22ga.
Re: Original Sheet Metal Gauge thickness? [Re: MoparJoe] #356380
06/24/09 09:50 PM
06/24/09 09:50 PM
SE Michigan
farmington Offline
mopar addict
farmington  Offline
mopar addict
SE Michigan
Not sure of the guages, but most modern outer metal is .028 - .031 thick.
Re: Original Sheet Metal Gauge thickness? [Re: topbrent] #356381
06/24/09 10:38 PM
06/24/09 10:38 PM
It is 18 ga for the sheet metal inside and out and 14 ga for the frame rails and cross members. 22ga is used on repops except for some floor pans which I have bought that are 18ga. Buy a guage indicator to check any sheet metal you buy so you get the correct ga.
Re: Original Sheet Metal Gauge thickness? [Re: ] #356382
06/25/09 12:32 AM
06/25/09 12:32 AM
SK,Canada
gregsrt Offline
gregsrt  Offline
SK,Canada
I just bought some sheet metal for making patches. Mic'd the original panel and it was between 18-20 gauge. I bought 18 gauge, any thinner and you can butt weld without burning through. 22 is probably what they use on new cars now, it's a bit thinner than the old stuff
An association of men who will not quarrel with one another is a thing which has never yet existed, from the greatest confederacy of nations down to a town meeting or a vestry. Thomas Jefferson
Re: Original Sheet Metal Gauge thickness? [Re: gregsrt] #356383
06/25/09 11:02 AM
06/25/09 11:02 AM
DPelletier Offline
DPelletier  Offline
All I can say is that I also mic'd them and there is no way any exterior panels of any muscle era mopar are 18ga.
....go ahead and use it for patches, but it's thicker than original
FWIW:
Cold Rolled Steel thicknesses:
- 18ga = .0478"
- 20ga = .0359"
- 22ga = .0299"
- 24ga = .0239"
Satin coat or galv. sheet
- 18ga = .0516"
- 20ga = .0396"
- 22ga = .0336"
- 24ga = .0276"
Had I known there was going to be this much confusion and controversy on the whole sheet metal thickness thing, I would have taken a micrometer to every panel in my car when it was down to bare metal.....oh well.
Don't forget that metal from the mills can vary by a though or so and not all micrometers are created equal; if you're using some pce of crap from a box store that cost $7.00, you may not be getting accurate measurements.
my 4 cents;
Re: Original Sheet Metal Gauge thickness? [Re: DPelletier] #356384
06/25/09 05:47 PM
06/25/09 05:47 PM
Arizona
jsully Offline
jsully  Offline
Arizona
While replacing the quarter panels on my 70 Challenger I did mic the existing panels just above my cut line (an inch or so below the rear quater top flared area) it is just uder .040".
I measured to compare with the goodmark quarter I bought which was less than .036, but read (either here or in Mopar Muscle) that the new panel had higher carbon steel than the originals (welding information).
Re: Original Sheet Metal Gauge thickness? [Re: topbrent] #356385
06/25/09 10:13 PM
06/25/09 10:13 PM
missouri, USA
moparmojo Offline
moparmojo  Offline
missouri, USA
I just checked my challenger firewall and floor I have been working on with a gauge I got with my welder. It was right at 20 gauge and would not fit in the 22gauge slot. I used 20 gauge patches.
Re: Original Sheet Metal Gauge thickness? [Re: DPelletier] #356386
07/04/09 11:58 AM
07/04/09 11:58 AM
FWIW:
- 18ga = .0478"
- 20ga = .0359"
- 22ga = .0299"
- 24ga = .0239"
- 18ga = .0516"
- 20ga = .0396"
- 22ga = .0336"
- 24ga = .0276"
my 4 cents;
I checked the thickness on my 69 coronet 500 and my 69 super bee and my buddies 69 RR with two different gauges and they show 18 ga.
