Current Viper V10 #356360
06/23/09 11:56 PM
06/23/09 11:56 PM
Seattle WA
RichV Offline OP
RichV  Offline OP
Seattle WA
The new Hot rod magazine section on variable valve timing mentions that the Viper V10 uses direct fuel injection. This seems to be true, but I have not been able find much information on it. I am looking for technical information on this engine. I have not found much in web searches. Does anyone know of a source of information on this engine?
Re: Current Viper V10 [Re: RichV] #356361
06/24/09 11:43 AM
06/24/09 11:43 AM
In the twisties
RokketRide Offline
super gas
RokketRide  Offline
super gas
In the twisties
Viper is not DI. Although the injectors are mounted in the head.
http://www.media.chrysler.com/dcxms/assets/specs/2009_DodgeViperSRT10Specifications_WN.pdf
Re: Current Viper V10 [Re: RokketRide] #356362
06/26/09 12:15 AM
06/26/09 12:15 AM
Seattle WA
RichV Offline OP
RichV  Offline OP
Seattle WA
Okay SFI, I thought the injector placement didn't look right for DI. Thanks for confirming it. I still would like to see a combustion chamber, piston and injector configuration for a two valve DI engine. If GM survives they will probably be the first to release a production version.
