Re: Can a newbie do base clear coat paint?
[Re: psycho_440]
#355770
06/23/09 05:32 PM
06/23/09 05:32 PM
Posts: 1,949 land of 10,000______'s
BDS871Cuda
Lots and lots of practice. Start out with small parts like doors, hoods, trunk lids. Over the years we have used PPG, Dupont, even the Napa crap. Now we only use House of Kolors single stage and it's just as good as a base clear. Then if you want, you can still put a clear on for the deep ocean look. We've painted about 5 custom Harley's with just the HOK single stage and never needed any clear.
Snap your neck, mega G-force launch, is all I want!
[Re: BDS871Cuda]
#355771
06/23/09 05:56 PM
06/23/09 05:56 PM
Posts: 2,261 IL
furious70
IL
I've done a couple cars and a couple bike tins in the past, none of the cars turned out anywhere as good as I would have hoped. You need a ton of patience to get the prep done right before you actually apply the color. The bike tins were a lot easier IMO, much smaller and easier to stay consistent on the smaller surface. I echo the advise that if you're gonna do it, you'll want to prep and paint several test panels (including the biggest hood you can find) before you touch your car.
70 Sport Fury 68 Charger 69 Coronet 72 RR
[Re: hemibeep]
#355773
06/23/09 06:58 PM
06/23/09 06:58 PM
Posts: 708 Mechanic Falls, Maine
4BBodies
mopar addict
mopar addict
I agree with psycho 440..........and will ad do not be afraid to try it, but get as many videos/books/whatever on the basics. If you have never painted then base/clear is very tricky to learn on, because so many things can go wrong. However, given the newer user friendly clears on the market, the great advice (here) if you are not afraid to ask, and plenty of homework, then yes, you could do it yourself. You will need to practice though, there is no way around that. A hood is best, as suggested above. After 20 years I will say that I still love painting, but after 100 or so cars it still is not an easy task. Good luck, hope you get the finish you desire!
[Re: MoparKansas]
#355775
06/25/09 01:25 AM
06/25/09 01:25 AM
Posts: 489 Chilly Northern, Minn.
71 Charger R/T
I would have to disagree with the others and say a base/clear is actually easier than a single stage in that you can put the base on pretty dry (easier for a beginner) which allows you to get a uniform coverage even with a metallic. Then as a newbie, you are bound to get some runs or sags in the clear if you are daring enough to try for a good gloss or if you are more conservative and tend to "dry it on" or orange peel it, You can always block out the clear and buff it. With a single stage metallic if you sag it you will need to block it flat and respray because the pigment and flake will be evident where the sag or run was. so in my opinion Base/clear is more forgiving for a new recruit. Just take your time on the base coat and put on as many conservative coats as it takes to get coverage (don't be concerned that it doesn't shine, it won't no matter what you do. after the base dries it's flat.) Your gloss is all in the clear (this is where i would concentrate my efforts in practicing) Horizontal is the easy surface, vertical is where you will sag or run it. practice on something with a pronounced body line like your Challenger fender has (that's where you will sag it) But not to worry, just make sure you have enough material on there (and you most likely will if it was enough to sag)so you can block it flat then buff it. You said you have the paint already so for the $2000.00 you are saving you can buy some nice tools like an HVLP gun, sanding blocks and a nice buffer and compounds that can be used time and time again, plus you'll have gained the experience to do your own paint work when you need to fix that door ding some careless dope puts in your pride and joy. Be assured, it takes a little knack to get it right the first time but it's not "Rocket Surgery" and you really can't screw things up so bad that it can't be redone. So I say, Go for it man and keep us posted to your progress. If I can help you out in any way let me know. Any questions, PM me.
[Re: 71 Charger R/T]
#355776
06/25/09 07:46 AM
06/25/09 07:46 AM
Posts: 9,982 Ansonia, CT
CJK440
Ansonia, CT
What color??
If its a non metallic just do single stage. Cheaper and you can color sand and buff it without changing it.
Metallic, go base/clear for reasons outlined above.
In either of these instances, runs, sags dust nib etc can all be worked out post painting.
If you are not painting in a professional booth don't try to get a perfect finish out of the gun, think of it as just laying down an even coat of material to work with later, because you will have to.
As a backyard bodyman, the best advice I can offer is follow the instructions.
2017 Contusion Blue Challenger T/A 392 M6 "BLKNBLU"
[Re: MoparKansas]
#355781
06/26/09 12:25 PM
06/26/09 12:25 PM
What the worst that can happen?
You have to sand it down and start over?
I'm all about trying something and doing it until I get it right.
#355783
06/27/09 12:40 PM
06/27/09 12:40 PM
71 Charger R/T
I would still say DO IT! I agree with GY3. People are making this sound like it's terrible hard to paint..... You say you're gifted with a spray can, Well, the technique is much the same just a much wider fan spray and better equipment. As for the color match, You are using the same paint so there should be no difference in pigment the only real variable is the way the flake lays down. and unless the same guy shoots the front as did the back, you cant say even an experienced guy can really do better if he doesn't know the exact conditions of when it was sprayed before. If you are really afraid of a mismatch because of your "newbie technique", Do a blend into the doors. That's a nice long panel to do a gradual blend that would never be detected by anyone. If you can lay down a respectable looking finish with a rattle can, I am confident you have the ability and understanding of how paint builds and lays down enough to shoot your own car (with some practice) You said you have a half gallon of paint left. If it is not reduced yet, you have a gallon of sprayable paint. You should be able to cover the entire outside of the car again with that much color. DuPont Chroma products are very nice to work with (It's my preference)So again I will say it, practice laying up some clear and give it a shot! And to answer your question, NO there is no black magic to this stuff just a little technique. The more you do the better you'll get.
[Re: MoparKansas]
#355785
06/30/09 11:33 AM
06/30/09 11:33 AM
Posts: 828 KS
MoparKansas
KS
[Re: MoparKansas]
#355786
06/30/09 11:34 AM
06/30/09 11:34 AM
Posts: 828 KS
MoparKansas
KS
