Correct finish for lower shock plate & u-bolts '69 Chgr
#355618
06/23/09 12:16 PM
06/23/09 12:16 PM
Posts: 3,967 S.I. N.Y.
1MYTGTX
S.I. N.Y.
Any one know the correct finish for the rear lower shock plates & u-bolts on a 69 Charger?
1MYTGTX
Re: Correct finish for lower shock plate & u-bolts '69
[Re: hemi70se]
#355620
06/23/09 08:53 PM
06/23/09 08:53 PM
Posts: 5,123 Warrenton, VA
RoadRunnerJD
Warrenton, VA
bare steel on both
Not on a 69. The shock mounts are gloss black and the u-bolts are natural. Natural is not silver looking but more like steel. I let mine get some surface rust. That's original looking!
Re: Correct finish for lower shock plate & u-bolts '69 Chgr
[Re: FJ5_Fish]
#355622
06/24/09 07:10 PM
06/24/09 07:10 PM
1MYTGTX
S.I. N.Y.
Crikies, what to do, what to do???? Seems like one of those things like the leaf springs....black or natural?
I have looked at a lot of pics of high end restos....half were black, half gray.
Redid mine again in the gray finish to add some contrast color to my black undercarriage....thanks for the input all!
1MYTGTX
[Re: 1MYTGTX]
#355623
06/24/09 08:34 PM
06/24/09 08:34 PM
Posts: 6,585 SE Pa.
LimeliteAero
SE Pa.
sounds good, Thats the direction Ill be going when I get to that point.
[Re: 1MYTGTX]
#355624
06/24/09 08:41 PM
06/24/09 08:41 PM
Posts: 4,258 State of Fascism
52savoy
State of Fascism
I can't vouch for any assembly line colors(parts) but I can tell you what I saw back then. Of all the '69 Charger R/Ts and '69 GTXs that I worked on. Not one had painted shock plates. BARE STEEL Whatever that's worth.
[Re: sixbbl69]
#355626
06/25/09 10:22 AM
06/25/09 10:22 AM
Posts: 8,828 Houston, Tx
hemi68charger
Houston, Tx
I can't see MaMopar painting the u-bolts and shock mounts. The leaf springs are a different story. I would always leave the u-bolts and shock mounts natural or at least natural looking.............
Troy
TroyHouston Mopar Connection Club'69 Charger Daytona 440 - auto - 4.10 Dana (now with 426 hemi) '69 Charger 500 440 - 4speed - 3.54 Dana '70 Road Runner 383 - 4speed - a/c (now with 440)
[Re: bremotorsports]
#355629
06/27/09 06:54 AM
06/27/09 06:54 AM
1MYTGTX
S.I. N.Y.
Thanks again all for the replies. Got finished with the pass side & it makes a world of difference over the black painted springs I used to run. Also the correct 7" u-bolts look much better than the generic 8" ones I was running from ESPO. I just took apart the drivers side & the center bolt was all twisted up like a pretzel. Had to go to a spring shop & get a replacement. I wish I wouldn't have gotten rid of my originals....The ESPO ones I have don't have all the provisions for the "correct" amt of spring clamps like the original Hemi springs had...... Carlisle is coming fast!!!
1MYTGTX
