Quarter panel extensions #355529
06/23/09 10:55 AM
06/23/09 10:55 AM
Ohio
jhayes63 Offline OP
jhayes63  Offline OP
Ohio
The mounting posts for my 69 Super Bee quarter panel extensions are worn. Some of the posts have enough threads to catch if I invert the nuts. Has anybody found a way to replace the mounting studs? I'm ready to try JB weld - I don't want to grind them off and use a sheet metal screw! And it looks like they don't make reproductions for 69 Super Bee or Coronet applications. Otherwise, these are perfect extensions. Any ideas?
Re: Quarter panel extensions [Re: jhayes63] #355530
06/23/09 12:29 PM
06/23/09 12:29 PM
near Port Huron, MI
Paul Offline
Paul  Offline
near Port Huron, MI
Have you tried flattening the 'teeth' on the stamped nut to make the opening smaller/tighter? Or finding a similar nut with a smaller inside diameter?
Re: Quarter panel extensions [Re: Paul] #355531
06/27/09 02:14 PM
06/27/09 02:14 PM
Ohio
jhayes63 Offline OP
jhayes63  Offline OP
Ohio
The nuts are original, I would hate to potentially ruin them. I could try smaller nuts, but I would have to use washers, hopefully there is enough length left on the posts. Thanks for the ideas!
