duster alinment issues #354180
06/21/09 11:09 PM
06/21/09 11:09 PM
CT USA
N
Nick Mineau Offline OP
N
CT USA
hi
im having a problem with my duster. if im driving over a hill and the supension unloads the car pulls left and then when it comes down it loads the torsion bars and pulls hard right. any ideas on this the car has done it sense i bought it this year. suespension seems tight. thanks
Re: duster alinment issues [Re: Nick Mineau] #354181
06/21/09 11:16 PM
06/21/09 11:16 PM
So Cal
autoxcuda Offline
autoxcuda  Offline
So Cal
Have you had it aligned? You need to fully check the suspension. Jack it up put the front on jackstands and have someone move the wheel while you look at every joint and bushing from 6 to 12 inches away. Yank on the centerlink up and down to see if the idler or pitman is bad.
Check the bolts on everything. Start with the steering box. Check and adjust the wheel bearings.
Re: duster alinment issues [Re: Nick Mineau] #354182
06/22/09 09:24 AM
06/22/09 09:24 AM
The Swamp
Sixpak Offline
Sixpak  Offline
The Swamp
Take a good hard look at where the lower control arm pivot goes thru the K frame. The welds around the tube in the K frame that support the lower control arm can crack and over time oval out the metal. If caught early enough it can be rewelded. Also check your strut rod and lower control arm bushings.
