Re: Widening stock rims
[Re: Scamp451]
#354103
06/21/09 10:43 PM
06/21/09 10:43 PM
RapidRobert
There's Stockton wheel which has been around for a long time but is on the left coast so yes some more local would be cheaper for you.
[Re: Crizila]
#354106
06/22/09 09:47 AM
06/22/09 09:47 AM
Posts: 15,487 Florida
scratchnfotraction
I just got a link on doing that,you supply the center of the rims they weld it in the wide ring gomango70bee,had the 10" wide stock rims with dog dish caps I will pass the info on pico wheel,north hollywood,...gary-818-982-0375 about 75$ a wheel maybe?
[Re: Scamp451]
#354107
06/22/09 12:24 PM
06/22/09 12:24 PM
Posts: 7,759 So Cal
HealthServices
Why would you even post that?
So Cal
In the wheels for sale section there is someone that does it.
Allen
Here's a novel idea, let's not throw a bunch of parts at the car hoping it will fix the problem and instead spend a little time diagnosing it first.
Life was a little easier when I was just a wrench.
[Re: hemibeep]
#354118
06/30/09 11:05 AM
06/30/09 11:05 AM
Posts: 1,357 central Florida
VL21
central Florida
Don't know anything about this place, i picked up the card at a bike event (I think) thinking about the alloy wheel thing myself. Wheel Works 1703 N. Rte.130 Burlington, NJ 08016 Tim Smith 609-387-4488 Card says alloy and aluminum rims repaired and widened.
It takes gasoline to interest me.
[Re: VL21]
#354119
06/30/09 11:12 AM
06/30/09 11:12 AM
Posts: 871 WA 98043
thecarfarmer
WA 98043
Speedway sells wheel hoops; IIRC they're the right diameter to take MoPar centers. Anyone for a 14" wide steelie with poverty caps? -Bill
Seduce the attractive, and charm the rest.
489 C.I.D., roller cam, aftermarket heads, tunnel ram, stock '54 Dodge rear axle assembly: which of these doesn't belong?
