Timing Chain too loose on new-rebuild stroker ..HELP
#353546
06/21/09 01:46 PM
06/21/09 01:46 PM
Posts: 2,506 Northern Pa
GLR
Northern Pa
I had a stroker engine 400/452 rebuilt again because the thrust bearing went bad. It was allign bored again and when I brought it back from the engine shop I started to assemble the engine and the timing chain is way too loose on this engine. If you make one side of the chain tight and put a straight edge on the opposet side and measure the amount of slop at the highest point is a little over a 1/4 inch! Do one of the timing chain companies have a shorter chain or larger gears to fix this problem? Please reply if you know how to fix this problem. Thank you! glr7069@ptd.net
Re: Timing Chain too loose on new-rebuild stroker ..HEL
[Re: ph23vo]
#353549
06/21/09 01:58 PM
06/21/09 01:58 PM
1_WILD_RT
Management Trainee
Management Trainee
Today? Who Knows?
you can buy a tensioner for it IIRC from one of the racing companies dan
Tensioner kit is for smallblocks... To bad cause it's a good option...
Re: Timing Chain too loose on new-rebuild stroker ..HELP
[Re: GLR]
#353554
06/21/09 04:54 PM
06/21/09 04:54 PM
Posts: 14,889 up yours
Supercuda
About to go away
About to go away
up yours
Bought a cheapo Cloyes (stock replacement) that was too loose on a stock unrebuilt engine, just preventative maintenance in replacing the chain at 100k miles on a 318. Sent it back and got a quality set, Edelbrock in this case, fit nicely.
Might be the kit is loose, but since you've had a line bore or two done, might need a undersized chain. Anyone know how to measure and tell for sure?
[Re: Supercuda]
#353556
06/21/09 06:17 PM
06/21/09 06:17 PM
Posts: 15,491 the boonies
aarcuda
the boonies
I bought a billet tc for my an and had the same amount of slack. For skits & grins I threw an older used cloyes true roller on it and it was tight. I'm running that chain and returned the billet one. Too bad too cause it was a great looking piece.
[Re: Kelob_pie]
#353559
06/22/09 08:28 PM
06/22/09 08:28 PM
Supercuda
About to go away
About to go away
up yours
Wait, let me pull the Rottler out of my pocket... oh wait.
Jo Blocks are a good idea, much cheaper than a Rottler, but not cheap. Maybe a center to center measurement with a dial caliper?
