Big Block Ol Pressure Issue???
#353348
06/21/09 08:19 AM
06/21/09 08:19 AM
Posts: 433 St.Clairsville Ohio
EV2RUNNER
St.Clairsville Ohio
Hey All, Helping a buddy that just put a fresh 383 in his coronet. He had it running yesterday and it only has 25lb of oil pressure at idle and it increased to 45psi at max when accelerating. He didnt run it long but you could watch the clear line going to the guage and it only had oil when past 1400 rpms..I know he checked all the bearing clearances and everthing was torqued to spec... Is the Oil pump losing prime?? Its a new Melling pump, he primed it with a drill before starting the motor.. Im out of Ideas here.. Thanks
MOPARTY!!! '71 RR 383 car.. '79 ASPEN R/T E58 car..
Re: Big Block Ol Pressure Issue???
[Re: EV2RUNNER]
#353350
06/21/09 08:29 AM
06/21/09 08:29 AM
Posts: 75,087 A Banana Republic near you.
JohnRR
Did he put an oil pressure guage on it when he primed it ? A fresh engine should be alot higher than that . I would also try ANOTHER GUAGE especially if the one he has is offshore made Did he disassemble the pump and check it to make sure it was clean ? Does it have one of those POS ORANGE oil filters on it wit ha name beginning with the letter F ???
[Re: blownzoom440]
#353352
06/21/09 08:37 AM
06/21/09 08:37 AM
EV2RUNNER
St.Clairsville Ohio
Yes Fram Filter, 10W40 Castrol Oil, The Guage is new, SunPro Though. We never disassembled the oil pump because it was new, are you thinking it may have something in it after initial startup? Am I wrong or should the line going to the guage have oil even at idle? Thanks
[Re: EV2RUNNER]
#353353
06/21/09 08:44 AM
06/21/09 08:44 AM
Posts: 601 Clintwood VA
johnedod
Clintwood VA
Its not unusual for the oil pressure line to have air in it so you won't see the oil in it all the time. I think 25 lb at idle is great. Better than mine.
Johnedod 68 Road Runner 71 Road Runner 78 Power Wagon
[Re: EV2RUNNER]
#353354
06/21/09 08:44 AM
06/21/09 08:44 AM
JohnRR
CHANGE THE FILTER , it's GARBAGE .
I would get ANOTHER guage to check it against and yes you need to disassemble the pump others have found junk in them OUT OF THE BOX , NEVER install anything without checking it first . Is the pump a HP or HV ?
As far as oil in the line at idle , only if you BLEED it when the engine is running , the line has air in it when assembled and it has no where to go unless you bleed it out, I would do that and see what it reads ? I don't like those sunpro guages , they are cheap for a REASON ...
[Re: JohnRR]
#353355
06/21/09 10:16 AM
06/21/09 10:16 AM
Posts: 2,179 S.E. Conn
Hoof Hearted
S.E. Conn
Not to hijack this thread, but I was a little concerned the other day when I took out my 3000 miles on the clock 496ci bee (after changing oil last month) and didn't really warm up the car for more than 4 mins or so and then hopped on the highway for a little 10 min ride to and fro the bank.
I noticed at "Cold idle" (temp outside was 65degrees) my oil pressure was 75psi. When I got on it at only 4000rpm the psi was at 95.
Once warmed up and on my way back home it was at 75 cruising at 3300rpm, hot idle was still 45psi.
I use Rotella T 15/40 and a Napa Gold, one of the best filters out there.
I know my motor is tight, but within specs. I guess this is ok for summer, but i'm hesitant to even start it in the winter at this weight.
Should I go with a lighter weight? I regularly beat the snots outa this thing.
2005 300C Hemi 2014 Ram ProMaster 2500
I Rekey, Repin old Chrysler locks and cut keys by code
[Re: Hoof Hearted]
#353356
06/21/09 10:49 AM
06/21/09 10:49 AM
Posts: 25,200 Upper Midwest
MoparforLife
Upper Midwest
15/40 is way too heavy for winter driving. 10/30 would be alot better.
[Re: cougar_cat_25]
#353359
06/21/09 01:51 PM
06/21/09 01:51 PM
Hoof Hearted
S.E. Conn
Quote: "Ha ha I think this is the first time I've heard 65 degrees called winter" Ummm, yeah. HA HA , you're hearing things and please "Read" the post you're refering to again, closely, unless you're prescription eyeglasses are bulletproof thick, then i'm sorry to nitpick. Thanks for playin though, it's been fun having you on the show. Bob, tell him what he's won... Yooooooooouve won a faaaaaabulous aaaaaalllll expenses paaaaaid trip to the eyyyyyyyye doctoooooor! da da dat dat da da daaaaa, da da dat dat da da daaaaa
[Re: Hoof Hearted]
#353360
06/21/09 02:06 PM
06/21/09 02:06 PM
MoparforLife
Upper Midwest
I think that he missed this part - "I know my motor is tight, but within specs. I guess this is ok for summer, but I'm hesitant to even start it in the winter at this weight"
[Re: MoparforLife]
#353361
06/21/09 06:47 PM
06/21/09 06:47 PM
Posts: 5,314 Carstairs, Alberta, Canada
dave571
absolutely
Try thinner oil. It will help.
Does it have a hi volume oil pump too?
Those are great for creating unnecessarily high pressures, heat, and taking horse power.
Excessive pressures are as detrimental as not having enough. Like winter starting the motor every time you hit the key.
Hi volume oil pumps were made for restoring pressure in worn out engines. A motor built to the tight end of stock specs only requires a stock pump. Otherwise you get a situation like this .
[Re: EV2RUNNER]
#353362
06/21/09 06:51 PM
06/21/09 06:51 PM
dave571
25 and 45 isn't too bad if the motor is at operating temp. If that's at cold start, then I think it the 45 a little low.
My own motor runs 25 hot at idle, but will peak at 55 when I wind it out.
