How often do dash ignitions go bad? 69 bee #353205
06/20/09 10:02 PM
06/20/09 10:02 PM
Tampa FL
hemibeep Offline OP
hemibeep  Offline OP
Tampa FL
Having intermittent issues with car running. checked all of the normal stuff. swapped ECU, swapped coil, checked ballast. all of these items about two years old. some times car runs fine. then other times will not start, or starts then stalls. Also, on occassion, car starts when key turned to "off"--almost seems to be running backwards...???
any thoughts?
Re: How often do dash ignitions go bad? 69 bee [Re: hemibeep] #353206
06/21/09 12:04 AM
06/21/09 12:04 AM
any thoughts?
you might pull your ign sw & go over it w your VOM
