Turn signal help Please #352949
06/20/09 07:16 PM
06/20/09 07:16 PM
Hunt Valley, Maryland
1fastrunner Offline OP
My turn signals don't work now that the steering column is back in place. They did work before it was removed. My emergency flashers work, so I guess the bulbs should all be good. The brake lights work, so the switch should be ok? Is there a flasher somewhere I could check?
Thanks,
Re: Turn signal help Please [Re: 1fastrunner] #352950
06/20/09 07:48 PM
06/20/09 07:48 PM
Grand Prairie,Texas
stumpy Online content
stumpy  Online Content
Grand Prairie,Texas
Yes there are two flashers one for turn signals and another for emergency lights.
Re: Turn signal help Please [Re: 1fastrunner] #352951
06/20/09 08:10 PM
06/20/09 08:10 PM
I'd start at the steering col(brake/tail)plug connector and when you R&R'd the col was anything done to the TS harness/wiring
Re: Turn signal help Please [Re: RapidRobert] #352952
06/20/09 08:24 PM
06/20/09 08:24 PM
Grand Prairie,Texas
Grand Prairie,Texas
Have you checked the fuse?
Re: Turn signal help Please [Re: stumpy] #352953
06/20/09 08:31 PM
06/20/09 08:31 PM
elyria, ohio
72gtx4speed Offline
72gtx4speed  Offline
elyria, ohio
the turn signal flasher is located on the ash tray frame on several models. pita to get to at times.
clem
when i grow up i want to be just like sunroofgtx, god please don't let me grow up.
Re: Turn signal help Please [Re: 72gtx4speed] #352954
06/20/09 09:22 PM
06/20/09 09:22 PM
Sorry,
I had to run out.
They did work before I took out the column.
I didn't touch the wiring.
Where can I find both flashers so I can switch them and see if that's the problem?
Re: Turn signal help Please [Re: 1fastrunner] #352955
06/20/09 09:45 PM
06/20/09 09:45 PM
I pulled out what appears to be the turn signal flasher, but have yet to locate the emergency one. Is there a way to test the flasher?
Re: Turn signal help Please [Re: 1fastrunner] #352956
06/20/09 10:43 PM
06/20/09 10:43 PM
You could jump 12V to it & run it out to the large filaments in 2 TS bulbs in parallel but it'd probably just be easier to find the other one & switch em for a test
Re: Turn signal help Please [Re: 1fastrunner] #352957
06/20/09 10:45 PM
06/20/09 10:45 PM
Cincinnati, Ohio
Challenger 1 Offline
Cincinnati, Ohio
Does the coluum need to be grounded on your model car? Four screws and the ash tray frame comes out and the turn signal flasher is attached to it. That's after you take out the ash tray.
Re: Turn signal help Please [Re: Challenger 1] #352958
06/21/09 06:54 AM
06/21/09 06:54 AM
That must be the one then. I removed the ash tray and found one there.
I get a replacement and see if that's it.
Re: Turn signal help Please [Re: 1fastrunner] #352959
06/21/09 08:55 AM
06/21/09 08:55 AM
Niles , Ohio
therocks Offline
therocks  Offline
Niles , Ohio
I was going to say at like 6 bucks just get a new one.That and try the 4 way now you have one out.If they work you have the ts one out.If they dont work now you pulled the 4 way.I buy the new style flasher that are electronic.I find they flasy better than the old OE style.Rocky
Chrysler Firepower
Re: Turn signal help Please [Re: therocks] #352960
06/21/09 10:12 AM
06/21/09 10:12 AM
Cincinnati, Ohio
Cincinnati, Ohio
The electroncs one are way better and will last longer and uses less juice to flash.
Re: Turn signal help Please [Re: therocks] #352961
06/21/09 10:41 AM
06/21/09 10:41 AM
You say new style flasher, Is it entirely different? or just the way the new replacement parts comes?
Thanks,
Re: Turn signal help Please [Re: 1fastrunner] #352962
06/21/09 11:55 AM
06/21/09 11:55 AM
Cincinnati, Ohio
Cincinnati, Ohio
Thanks,
Useally the cheap light duty ones are the ones our cars came with, nowadays they make electronic ones that can flash all day like in a mail delivery vehicule. They can be the same shape, but come in many sizes depending on how many bulbs you want flash. Any of the 2 prong flashers will work, but the round ones will fit your flasher bracket that attaches to the ash tray frame.
Re: Turn signal help Please [Re: Challenger 1] #352963
06/21/09 07:29 PM
06/21/09 07:29 PM
Well, it's not the flasher, because the new one won't make the blinkers work. I have the steering wheel off. but I don't know what to test. Could it be the switch even though the brake lights work?
Re: Turn signal help Please [Re: 1fastrunner] #352964
06/21/09 07:47 PM
06/21/09 07:47 PM
wisconsin
dodger1 Offline
dodger1  Offline
wisconsin
When my flasher was bad the turn signals would stay lit when I put the turn signal on but they wouldnt flash , try the other flasher my car had one by the fuse box and one by the ashtray, John
Re: Turn signal help Please [Re: dodger1] #352965
06/21/09 08:00 PM
06/21/09 08:00 PM
John
Are they both round? The emergency flashers work, but nothing with the turn signals. Where by the fuse would it be?
Re: Turn signal help Please [Re: 1fastrunner] #352966
06/21/09 10:19 PM
06/21/09 10:19 PM
the brake pedal switch sends fire to the TS switch via one wire which sends it to both brake lights in the rear(2 seperate wires)(R&L) & when you push the stalk down it keeps the right side brake light connected but opens the left side & redirects it's current to the TS flasher which intermittently opens/closes & sends current back to the TS switch & out to the drivers rear brake light(the large filament). The brake lights and the turn signals use the same large filament in each 2 filament bulb it just makes one side intermittent depending on which way(up or down) the stalk is pushed so yes eyeball the TS contact points carefully(and w your VOM) see whats not making contact that should be.
Re: Turn signal help Please [Re: RapidRobert] #352967
06/21/09 11:26 PM
06/21/09 11:26 PM
wisconsin
dodger1 Offline
dodger1  Offline
wisconsin
I would try to locate your other flasher,I quess you could remove the one you found and see if the emergency flasher still work if they dont then that one is for the emergency lights and there should be another one, my Demon has two. I think you might have a bad connection somewhere if the turn signals worked before you changed the steering column . John
Re: Turn signal help Please [Re: 1fastrunner] #352968
06/22/09 01:06 AM
06/22/09 01:06 AM
Vancouver, WA
MoparMarq Offline
MoparMarq  Offline
Vancouver, WA
This may be stating the obvious, but with the steering wheel removed, it's more possible the turn signal stalk - and hence, the switch - will get damaged during setting the column down somewhere. Were you quite careful handling the column out of the car? The turn signal switch can get damaged in such a way as for the brake lights and hazards to still work, but the turn signals not.
I would check continuity of the wiring in the column harness with the turn signal switch in various positions to see if there is continuity in the appropriate circuits.
I don't know how to work my scanner, but check page 8-159 in your '72 FSM.
Turn signal switch wiring:
Light green - left front.
Tan - right front.
Pink - hazard flasher.
Red - turn signal flasher.
Dark green - left rear.
Brown - right rear.
White - stop light switch.
So, with the turn signal switch off (centered) and hazards off:
Continuity with white, brown and dark green.
No continuity with anything else.
With left turn signal selected:
Continuity with red, dark green, and light green.
Continuity with white, brown.
With right turn signal selected:
Continuity with red, tan, and brown.
Continuity with white, dark green.
A much easier way, if you have a spare known-good turn signal assembly, is plug that into the car harness. Then jumper the the batt and accessory terminals on the fuse block to power the turn signal flasher, and see how that works.
Another, cruder way would be as follows:
jumper the batt and accessory terminals on the fuse block to power the turn signal flasher. Then, touch a screwdriver to the brown and dark green terminals (which are adjacent) on the car harness to activate the left rear turn signal. This will at least tell you if the flasher is working...
Good luck.
-Marq
