Fan shroud options? #352794
06/20/09 05:03 PM
06/20/09 05:03 PM
Missouri
MY340 Offline OP
MY340  Offline OP
Missouri
Besides the factory shrouds has anyone used an aftermarket/univeral one with success or made there own?
Looking at my options and please post pics if you can! I have a stock 22" radiator with clutch fan setup.
Thanks!
1970 FE5 Duster 360/904/3.91's SOLD 1973 TB3 SpaceDuster 340/4spd/4.10's SOLD Moparless for now but when the opportunity is right I'll have another one.
Re: Fan shroud options? [Re: MY340] #352795
06/20/09 07:47 PM
06/20/09 07:47 PM
Here
DirectSubjection Offline
Tacohead. The First and Only
Here
Saw this company at Carlisle custom making them:
http://mahaffeymotorsports.com/FanShrouds.htm
My setup is too screwy for one, I just have the cheapie universal chrome thing which is more of a guard for my hands.
Ride eternal, shiny and chrome
Re: Fan shroud options? [Re: DirectSubjection] #352796
06/20/09 10:51 PM
06/20/09 10:51 PM
Mississippi
Mr. T Offline
Mr. T  Offline
Mississippi
I also have the factory 22" single row radiator on my 67 Dart.After tolerating heat issues with it for quite a while,I finally ordered a 24" aluminum radiator with 3 rows.I'm hoping that I won't need a shroud with it.I also have the clutch fan set up with a small electric fan mounted in front,using a toggle switch.
Re: Fan shroud options? [Re: Mr. T] #352797
06/21/09 10:36 AM
06/21/09 10:36 AM
Maryland
GO_Fish Offline
GO_Fish  Offline
Maryland
Depends on what you are looking for when it is finished. Is this on a show car or a driver?
On my 68 B'cuda, the original 22" radiator had no shroud with its 318. When I went to a 360, the old rad was running hot. I found that a /6 radiator shroud from a mid-70's valiant can be mounted upside down and works perfect on a v8 application. Some minor clearancing and re-drilling the mounting holes. Not show, but works for my driver.
Scott B. "I'm a self-made man... I started with nothing, and I still have most of it!" 68 360 rusty B'cuda 'vert (GO Fish)13.59@ 98.72 mph 69 340 GTS stock 14.18@ 95.60 mph 01 5.9L Ram 1500 Quad Cab 4x4 01 3.5L 300M 16.23@ 86.97 mph
Re: Fan shroud options? [Re: GO_Fish] #352798
06/21/09 02:57 PM
06/21/09 02:57 PM
Berlin, N.J.
abodyjoe Offline
abodyjoe  Offline
Berlin, N.J.
djvcuda made one for me. looks good and works very well..
It's better to keep your mouth shut and give the impression that you're stupid than to open it and remove all doubt.
www.MoparMisfits.com
Re: Fan shroud options? [Re: abodyjoe] #352799
06/21/09 05:29 PM
06/21/09 05:29 PM
Az
Crizila Offline
Crizila  Offline
Az
Fabbed up mine from a sheet of 1/16" aluminum. Riveted it together.
Fastest 300
Re: Fan shroud options? [Re: Crizila] #352800
06/21/09 07:18 PM
06/21/09 07:18 PM
Holland MI Ottawa
2
2boltmain Offline
2boltmain  Offline
Holland MI Ottawa
Allstar is a brand that makes tons of oval track parts. Lane Automotive stocks them. Allstar make various dimensions of aluminum fan shrouds much like the one pictered in the beginning of this post (not polished though). They are inexpensive and with the many different sizes you should be able to nail it it right on.
Keep old mopars alive.
Re: Fan shroud options? [Re: 2boltmain] #352801
06/21/09 10:01 PM
06/21/09 10:01 PM
Missouri
MY340 Offline OP
MY340  Offline OP
Missouri
Thanks guys for the great pics and names to check out.
