Re: problem w/ edelbrock carb fuel just keeps pouring in
[Re: 440dustr]
#352371
06/20/09 12:36 AM
06/20/09 12:36 AM
Posts: 7,759 So Cal
HealthServices
Why would you even post that?
So Cal
I don't believe these can take much fuel presure what are you at?
Allen
Here's a novel idea, let's not throw a bunch of parts at the car hoping it will fix the problem and instead spend a little time diagnosing it first.
Life was a little easier when I was just a wrench.
[Re: SomeCarGuy]
#352373
06/20/09 01:45 AM
06/20/09 01:45 AM
Posts: 4,861 Riverside, Ca
R70RUNNER
Riverside, Ca
Yep, as said fuel pressure needs to be low... I run 4.5 to 5.. all it needs
Current cars: 2000 Dak Quad Cab, 2012 Challenger,1970 Road Runner, 1994 Firehawk
1966 Coronet post sedan, 1988 Corvette, 2005 Magnum RT all SOLD
R70RUNNER<---VP Inland Empire Chapter of the MPM
[Re: 440dustr]
#352375
06/20/09 08:44 AM
06/20/09 08:44 AM
Posts: 14,889 up yours
Supercuda
About to go away
About to go away
up yours
I seriously doubt it the fuel pump, 6 psi isn't that much, if that is what you have. Did you check for floats full of gas? I have had that happen several times in the 20 years I've had my 1407 carb. Also, did you check the float level and drop? Did you inspect the seats and especially the tip of the needle for burrs/jun?
Steve
