Mallory front belt drive dist. anyone running one? #352326
06/19/09 11:45 PM
06/19/09 11:45 PM
sycamore,ohio
BobsProFab Offline OP
sycamore,ohio
im going with a front belt drive setup and crank trigger.
just wondering how do they compare to the MSD and the Jesel front belt drive dist.
link:
http://www.jegs.com/i/Mallory/650/20901/10002/-1
any info would be great
thanks Bob
Re: Mallory front belt drive dist. anyone running one [Re: BobsProFab] #352327
06/20/09 12:19 AM
06/20/09 12:19 AM
Rittman Ohio
fourgearsavoy Offline
Rittman Ohio
Bob have you seen AndyF's drive mounts yet? They are very nice and he can answer your questions.
Gus
64 Plymouth Savoy
Dana 60
Re: Mallory front belt drive dist. anyone running one? [Re: BobsProFab] #352328
06/20/09 01:24 AM
06/20/09 01:24 AM
AndyF Offline
AndyF  Offline
I've had all three setups in the shop. I prefer the Jesel, especially if you're running a Jesel belt drive.
The real problem is getting the distributor to clear the water pump but I have several solutions for that issue.
Re: Mallory front belt drive dist. anyone running one? [Re: BobsProFab] #352329
06/20/09 01:26 AM
06/20/09 01:26 AM
AndyF Offline
AndyF  Offline
Here is a thread in the new parts section that covers some related topics: https://board.moparts.org/ubbthreads/show...e=1#Post3858940
Re: Mallory front belt drive dist. anyone running one? [Re: AndyF] #352330
06/20/09 08:57 AM
06/20/09 08:57 AM
sycamore,ohio
sycamore,ohio
water pump is no issue on my motor, i would just have to make spacers to extend it out for clearance for the belt
the motor will see 10,000 rpm thru the lights with my gear / tire combo
Andy do you sell the 2 bolt system for all 3 setups
Re: Mallory front belt drive dist. anyone running one? [Re: BobsProFab] #352331
06/20/09 10:22 AM
06/20/09 10:22 AM
AndyF Offline
AndyF  Offline
The mounting plate that I sell is designed for a Jesel distributor on a big block with a 3/8 motor plate. The motor plates that I sell are pre-drilled for the distributor bracket so it all works together as a system. One of my plates might work for you but the odds are that you would need to use some spacers and/or get a different belt from Gates to make it all work.
