1970 challenger rtse back glass repair #352246
06/19/09 10:02 PM
06/19/09 10:02 PM
Canada
sam c Offline OP
sam c  Offline OP
Canada
Hello I am having some trouble trying to find nice se back glass.Mine is almost usable except for a couple of small deep scratches in one area.Found this link and just wanted to know if anybody had there's done this way Thanks http://www.youtube.com/watch?v=ca5OvULMVuA
Re: 1970 challenger rtse back glass repair [Re: sam c] #352247
06/20/09 09:12 AM
06/20/09 09:12 AM
capac michigan
MCB Restorations Offline
capac michigan
Do yu happen to have an extra SE back glass stainless trim? I need the two small corners.
MAtt @ MCB www.tuffwheelrestoration.com
Stainless Steel and Aluminum trim restoration by MCB Restorations. We offer show quality trim restoration for all brands but specialize in Mopar. See our website for other examples www.mcbrestorations.com or give us a call at (810) 395-7162
Re: 1970 challenger rtse back glass repair [Re: sam c] #352248
06/21/09 09:30 AM
06/21/09 09:30 AM
greenfield, ind.
P
PLMCRZY Offline
PLMCRZY  Offline
P
greenfield, ind.
you could probably make your window look better, i wouldn't expect results as good as his. you have a tempered back glass. windshields are laminated, annealed glass. wiper marks are different than the scratches you normaly see on back windows. dennis
Re: 1970 challenger rtse back glass repair [Re: PLMCRZY] #352249
06/21/09 01:33 PM
06/21/09 01:33 PM
Canada
sam c Offline OP
sam c  Offline OP
Canada
mcb metal sorry I do not have any extra corner peices.I decided to call the company that does this procedure,and they claim that the glass could be fixed without any warpage.Considering the repair area is small it should be an easy fix.My only problem would be shipping since I live in Canada and they are in California.I wish I would of found them before because then I would of sent them all my original glass so that shipping would have been worth the expense.
Re: 1970 challenger rtse back glass repair [Re: PLMCRZY] #352250
06/21/09 04:16 PM
06/21/09 04:16 PM
Absolutely correct about laminated and tempered. However, tempered is 5X stronger than laminated. You actually have to be way more careful with windshields than you do with side and rear glass. Especially if the windshield has a bullseye or chip. That becomes your achilles heel, the spot where it wants to crack. I wont even touch a windshield with a bullseye in it for that reason. I'll resurface side and rear tempered all day long! Hope that makes sense.
I tried to make the video better by making it HD. You just have to make sure you click the HD button. Its bigger and clearer that way. Oh, and also, left click and "watch on youtube".
Hope that helps.
Rick Evans
Unscratch The Surface website
rick@unscratchthesurface.com
YouTube 1960 Alfa Romeo Windshield Resurfacing - No Distortion
