disharge at idle 68 Charger #351990
06/19/09 06:11 PM
06/19/09 06:11 PM
California
70SportSatellite Offline OP
super street
super street
California
Have not verified this with meter but gauge shows discharge at idle than a recharge after acceleration then returns to center. Currently has 50amp alt and electronic regulator. (68 Charger)Is a higher output alt the solution? say a 75amp? Could it be something else? Thanks
Re: disharge at idle 68 Charger [Re: 70SportSatellite] #351991
06/19/09 07:05 PM
06/19/09 07:05 PM
Chicago Burbs
sthemi Offline
sthemi  Offline
Chicago Burbs
Has it ever worked correctly, is this a new problem.?
IT is typical for those cars to slightly discharge at idle with the lights, or blower motor on.
The alternator will just barely power the brake lights without discharging.At idle..
Correct Pulleys, corroded wires, amps for the Stereo are possible reasons.
Also if you have a weak or bad alternator diode, you will have the same problem.
Putting a larger alternator will fry the wiring, check the tech archives..
Re: disharge at idle 68 Charger [Re: sthemi] #351992
06/19/09 07:46 PM
06/19/09 07:46 PM
scratchnfotraction Offline
have the alt checked first,IMO
weak diodes slowly show up
and a 68..I would not go with more juice with out some mods and bypass of the ampmeter gauge and get it out of the bulkhead connector and gauge cluster
scratchin
Re: disharge at idle 68 Charger [Re: scratchnfotraction] #351993
06/20/09 08:20 AM
06/20/09 08:20 AM
You might check your voltage drops and or clean EVERY terminal/connection for a start. Unless you have rewired it(some of)those connections have been untouched for over 4 decades
Re: disharge at idle 68 Charger [Re: RapidRobert] #351994
06/20/09 09:14 AM
06/20/09 09:14 AM
up yours
Supercuda Offline
About to go away
Supercuda  Offline
About to go away
up yours
i agree, my 65 Cuda (stock charging system right down to teh mechanical regulator) doesn't discharge at idle, anymore. Nice and bright, but I haven't tried it with the AC on, simply because I haven't gotten the AC working yet, not too hot on an R134 conversion and R12 is too expensive.
Don't be the exception.
Re: disharge at idle 68 Charger [Re: Supercuda] #351995
06/20/09 10:48 AM
06/20/09 10:48 AM
Seattle, WA
3
375inStroke Offline
Special needs person
375inStroke  Offline
3
Seattle, WA
I don't see how a higher output alternator would help anything. Discharge at idle is due to not enough voltage from the alternator. A higher output alternator would have higher gauge wire inside, thus, it would have fewer windings, reducing voltage for a given rpm. It could handle more current at higher rpms, but that's not your problem.
Re: disharge at idle 68 Charger [Re: 70SportSatellite] #351996
06/20/09 01:39 PM
06/20/09 01:39 PM
MNobody Offline
MNobody  Offline
What's the idle rpm's set at?
