Cam base circle question? #351217
06/18/09 08:40 PM
06/18/09 08:40 PM
Kalispell Mt.
HotRodDave Offline OP
Kalispell Mt.
Does a comp 270S cam have the same base circle as a factory 273 solid cam?
Re: Cam base circle question? [Re: HotRodDave] #351218
06/18/09 09:22 PM
06/18/09 09:22 PM
Eagle, Idaho
Neil Offline
The Doctor is in.
Neil  Offline
The Doctor is in.
Eagle, Idaho
Don't see why it wouldn't be..... Call and ask I guess.
I though the small base circle was mainly a small block chevy deal since the cam and crank journals are so close together on those engines. I had to special order a small base circle Lunati Voodoo cam when I put the longer 5.7 rods in my 400.
