piston to valve clearance ? #350571
06/17/09 10:25 PM
06/17/09 10:25 PM
Newark, OH
springers340dart Offline OP
Newark, OH
for some reason the car is bein a slug big time and i've almost run out of options to see why it's running this way. but i do have the cam in straight up and a .629 lift exhaush and .620 intake and i'm at .095 clearance now on exhaust. if i advance it will it bring that closer of farther apart?
Re: piston to valve clearance ? [Re: springers340dart] #350572
06/17/09 10:34 PM
06/17/09 10:34 PM
MOPAR HEADQUARTERS IN ALDEN NY
hemigod426 Offline
hemigod426  Offline
more advance closer, think its about 10 thou for each degree, go 4 degrees more max with auto and your setup
MOPAR OR NO CAR
Re: piston to valve clearance ? [Re: springers340dart] #350573
06/17/09 11:19 PM
06/17/09 11:19 PM
Affton MO
Q
qwkmopardan Offline
qwkmopardan  Offline
Q
Affton MO
advance the cam and your exh. piston to valve will get larger and the int. piston to valve will get smaller. Be sure to recheck piston to valve clr after changes are made.
Re: piston to valve clearance ? [Re: qwkmopardan] #350574
06/18/09 09:45 AM
06/18/09 09:45 AM
IN
Irun5snd8th Offline
Irun5snd8th  Offline
IN
Advancing brings the intake closer, retarding brings the exhaust closer. I see about .025 for every 2 degrees
AFCO, Rons Fuel Injection sponsored Dodge Challenger Mention Street Lethal Motorsports
Re: piston to valve clearance ? [Re: Irun5snd8th] #350575
06/18/09 05:46 PM
06/18/09 05:46 PM
Newark, OH
Newark, OH
thanks yall for the replies and have fun over in pittsburgh, just found out that i'm pretty sure i have a cracked head.
