Re: 440 six pack - intake manifold - paint burn off
[Re: newbee69]
#350556
06/17/09 10:24 PM
06/17/09 10:24 PM
Posts: 18,157 Mass
DAYCLONA
Mass
didnt burn off mine.
.. ,....my motor is painted in Dupont Centari Aycrlic Enamel, fully function heat crossover/choke, as factory
[Re: newbee69]
#350557
06/17/09 10:24 PM
06/17/09 10:24 PM
Posts: 533 Williamsport, PA
Rob440Magnum
mopar addict
mopar addict
Williamsport, PA
didnt burn off mine
To confirm, you do not have a functioning heat riser, and you do not have the heat crossover blocked off with the valley tray, correct?
[Re: Rob440Magnum]
#350558
06/18/09 08:56 AM
06/18/09 08:56 AM
Posts: 75,070 U.S.S.A.
JohnRR
U.S.S.A.
If you don't have the heat riser and you don't have the heat crossover blocked off so the choke works, will the intake manifold get hot enough to discolor or burn off some of the hemi orange paint on the aluminum intake manifold?
Any suggestions?
Thanks, Rob
What paint are you planning on using ? if it's MP paint I think that stuff will burn off if you leave the hood open at a car show on a stone cold motor exhaust is still going to pass thru the crossover and heat up the intake even without the heat riser
[Re: Rob440Magnum]
#350559
06/18/09 11:02 AM
06/18/09 11:02 AM
Posts: 30,460 Florida STAYcation
dOoC
The village idiot's idiot
Florida STAYcation
Any suggestions?
Thanks, Rob
They have a kind-of hemi-orange header paint that would work fine.
[Re: dOoC]
#350560
06/18/09 11:12 AM
06/18/09 11:12 AM
Posts: 3,106 Ridgeland Wi
mopars_1
Ridgeland Wi
hmm.. burnt off on dads charger right away. has functioning heat crossover.
1971 Plymouth Duster 340 auto 1937 Plymouth PT50 1969 Dodge Dart Swinger 340 4 speed 2013 Ram laramie 2500 hemi 2008 Harley FLSTSB springer
