aluminum head swap #350234
06/17/09 05:32 PM
06/17/09 05:32 PM
Watertown, WI
MikeyT Offline OP
MikeyT  Offline OP
Watertown, WI
Ok folks
I'm getting ready to swap over my well used 346 heads to a set of 440 source heads.
Here is the engine
440 engine with edlebrock ch4b intake. 770 street avenger carb. Hedman 1 3/4 headers
What are the best gaskets to use when changing over to the aluminum heads?
Can I also use my stock rocker assembly or must I get adjustable ones?
I'm really excited about this change!
Mike
1969 Dodge Dart Swinger
Re: aluminum head swap [Re: MikeyT] #350235
06/17/09 05:45 PM
06/17/09 05:45 PM
Overpriced Housing Central
RobX4406 Offline
RobX4406  Offline
The rockers you are currently running should be fine if running the same cam.
Make sure the fire ring on your head gasket doesn't overhang the combustion chamber. Don't know if you saw the earlier threads about that issue with some of the commonly used HG's. Don't know if 440source has fixed that or not. If you are using the 440source HG's you should be good to go. Check to make sure.
Re: aluminum head swap [Re: RobX4406] #350236
06/17/09 11:46 PM
06/17/09 11:46 PM
Watertown, WI
MikeyT Offline OP
MikeyT  Offline OP
Watertown, WI
thanks Rob!
Mike
Re: aluminum head swap [Re: RobX4406] #350237
06/18/09 12:48 AM
06/18/09 12:48 AM
Eagleville Tn.
rtstreet Offline
rtstreet  Offline
Eagleville Tn.
Re: aluminum head swap [Re: rtstreet] #350238
06/18/09 11:02 AM
06/18/09 11:02 AM
Niles , Ohio
therocks Offline
therocks  Offline
Niles , Ohio
I used FelPros marines on my heads.Mine were the first sets.Id have the valves checked because the valve job is OK but not great.Mine needed lapped.What cam are you running>My .588 we upgraded the spreings retainers and locks.Went to 10 degree pieces.With a smaller cam and auto they would have been good to go.Never trust an out of the box part.Mine have been on over a year and no problems.Rocky
Chrysler Firepower
Re: aluminum head swap [Re: therocks] #350239
06/18/09 12:08 PM
06/18/09 12:08 PM
Rock Springs
Bob_Coomer Offline
Bob_Coomer  Offline
Rock Springs
Some guys will reccomend high dollar Coemtics, and race gaskets.
I reccomend the cheap FelPro PT gaskets that you can get through Mancini or Jegs/Summit for $35-$40 a pair. They have a bore of 4.520 and hold up just fine.
Matter of fact I have used these gaskets on 493 cubic inch Indy head engine with 12:1 compression and Alky. I even reuse them at least once before I toss them.
If everything is nice and flat, Big block Mopars have a great cylinder head sealing design.
Here they are and $17 each. Now worries with overhang with these babies.
http://chucker54.stores.yahoo.net/felbrbenper.html
Re: aluminum head swap [Re: MikeyT] #350240
06/18/09 04:32 PM
06/18/09 04:32 PM
A Banana Republic near you.
JohnRR Offline
JohnRR  Offline
I'm ASSuMEing that you mean stamped steel rockers when you say STOCK ? If so check and make sure the rockers clear the spring retainers thru the FULL RANGE OF MOTION , one person posted somewhere about an issue they had (droped a valve ??) because they didn't check .
Re: aluminum head swap [Re: JohnRR] #350241
06/18/09 06:24 PM
06/18/09 06:24 PM
Watertown, WI
MikeyT Offline OP
MikeyT  Offline OP
Watertown, WI
Thanks everyone! john I did mean the stamped steel rockers. Thanks for that I'm planning on having the heads looked at before they go on the car.
Mike
Re: aluminum head swap [Re: MikeyT] #350242
06/18/09 06:39 PM
06/18/09 06:39 PM
Chino Valley
RodStRace Offline
RodStRace  Offline
Chino Valley
Check the heads, but also make sure that:
They don't bottom out on the dowels. Drop them on without gaskets to make sure.
Run your intake and exhaust bolts and any exterior bolts (Alt. P/S) into the holes before you install.
You have the right head bolts and washers along with the gaskets.
You have the right spark plugs.
After putting on the rockers, roll over the motor and watch the valvetrain. Make sure the pushrods clear the head, and check the rocker to valve tip pattern.
Some of this should not bite you, but these are some of the things others have asked about after installing out of the box....
I hope that John or someone else would provide a better checklist, but there are so many little things that a knowing eye can see that such a list could be pages long. This would apply to even stock heads, BTW.
