Ziebart Removal #349817
06/17/09 10:18 AM
06/17/09 10:18 AM
Anonymous OP
Anonymous OP
I recently purchased a '71 Road Runner from the original owner in Chicago. The car is covered liberally with Ziebart, a product widely used in northern states and Canada to prevent rust. My car has it everywhere and I would like to remove it in some places. Does anyone have a suggestion on how to remove this stuff. I visited with Ziebart staff people and they didn't have a suggestion. I've tried your regular solvents, etc, with no luck. I'd appreciate any ideas.
Re: Ziebart Removal #349818
06/17/09 10:23 AM
06/17/09 10:23 AM
85086
moparpollack Offline
Lil Herman
Lil Herman
85086
Is this inside the panels or underneath the car? Challenger1 has a steam cleaner or power washer that removes undercoating without scraping.
Re: Ziebart Removal #349819
06/17/09 10:30 AM
06/17/09 10:30 AM
85086
Lil Herman
Lil Herman
85086
Re: Ziebart Removal #349820
06/17/09 01:08 PM
06/17/09 01:08 PM
middle of the country
aar1 Offline
aar1  Offline
Are you talking about the undercoating or the rustproofing crap they spray inside the doors etc? If it is the stuff they spray in the doors and such, WD40 will take it off without hurting the paint.
Re: Ziebart Removal #349821
06/17/09 03:20 PM
06/17/09 03:20 PM
Anonymous OP
Anonymous OP
Ziebart is typically sprayed through holes drilled through places on the body, such as under sill plates, etc. They also spray it up into the wheelwells, etc for protection. The previous owner of this car must have told the guys that did the work that if "x" amount of product is good, "2x" must be better. It is all over the place. The whole inside of the trunk was sprayed with this stuff. It is under the hood, on the ram air assembly, inner fender wells,... It's crazy. What I have removed is very labor intensive. The sheet metal is solid as a rock, but at the pace I'm going, it will take forever. Car otherwise looks great. 53,000 one-owner car. Red with black interior. Just need to clean it up a bit. Thanks for your replies.
Re: Ziebart Removal #349822
06/17/09 03:33 PM
06/17/09 03:33 PM
Anonymous OP
Anonymous OP
I just tried applying some WD40 to this stuff. Didn't affect it much differently than other stuff I've tried- mineral spirits, acetone, etc. Thanks for the suggestion. I will spray some on a couple of spots liberally today before I leave my shop and see how it does in the morning.
Re: Ziebart Removal #349823
06/17/09 03:38 PM
06/17/09 03:38 PM
Cincinnati, Ohio
Challenger 1 Offline
Cincinnati, Ohio
I've found gasoline works the best, but I wouldn't recomend it on a assembled car. A heated pressure washer will do the job, a bada$$ one.
Re: Ziebart Removal [Re: Challenger 1] #349824
06/17/09 03:45 PM
06/17/09 03:45 PM
85086
Lil Herman
Lil Herman
85086
Do you soak the undercoating in gasoline? If so how long?
Re: Ziebart Removal [Re: moparpollack] #349825
06/17/09 03:54 PM
06/17/09 03:54 PM
NW Ohio
6pkaar Offline
6pkaar  Offline
NW Ohio
Liberly apply the gasoline, sit back and light up a cigarette.....it won't be long before the undercoating is blown right off!
Re: Ziebart Removal [Re: 6pkaar] #349826
06/17/09 03:59 PM
06/17/09 03:59 PM
85086
Lil Herman
Lil Herman
85086
We'll try that on your car first and see how it goes.
Re: Ziebart Removal [Re: moparpollack] #349827
06/17/09 05:06 PM
06/17/09 05:06 PM
Cincinnati, Ohio
Cincinnati, Ohio
Only about 2-5 mins and then blast it off with hot water.
Re: Ziebart Removal #349828
06/17/09 07:38 PM
06/17/09 07:38 PM
San Diego CA
65 Hemi Offline
65 Hemi  Offline
San Diego CA
I have been in the coatings industry for years and have done alot of work with ziebart dealers. A heat induction unit work best with a putty knife. See if a local body shop or Rhino Linings dealer will rent you theirs.
Doug
MOPAR or NO CAR!!!
1965 Dodge Coronet soon a 6.1 Hemi with a Magnson blower 810 hp on pump gas
1964 Dodge Polara 582" Indy alum Block 426-1RA heads,
1933 Plymouth PE all Steel, LT1 4L60E
1959 Plymouth Savoy 33,000 mile survivor
Old cars are never done. They are ongoing projects!
Re: Ziebart Removal [Re: 65 Hemi] #349829
06/17/09 08:33 PM
06/17/09 08:33 PM
Cincinnati, Ohio
Cincinnati, Ohio
The OP car is togeather and removing the stuff is not easy.
But if the car was stripped and on a rotisseire, then a "heat induction unit and a putty knife" is definetly not the best way to do it.
Re: Ziebart Removal [Re: Challenger 1] #349830
06/17/09 08:42 PM
06/17/09 08:42 PM
Ohio
LS-300 Offline
LS-300  Offline
Ohio
The stuff they give you for overspray works to soften it. Surprise its just kerosene
1979 Chrysler 300 1968 Barracuda project
Re: Ziebart Removal [Re: LS-300] #349831
06/17/09 09:00 PM
06/17/09 09:00 PM
pennsylvania
tbone4343 Offline
tbone4343  Offline
pennsylvania
took mine off complete with air chisel set at low psi knocked that stuff right off .
Re: Ziebart Removal #349832
06/17/09 11:33 PM
06/17/09 11:33 PM
Anonymous OP
Anonymous OP
Thanks for all the suggestions. I appreciate it very much.
Re: Ziebart Removal [Re: 6pkaar] #1976680
12/26/15 06:47 PM
12/26/15 06:47 PM
Mesa, Arizona
dart4forte Online boogie
dart4forte  Online Boogie
Mesa, Arizona
Originally Posted By 6pkaar
Do you soak the undercoating in gasoline? If so how long? <img src="/ubbthreads/images/graemlins/1343795-scratchchin.gif" alt="" />
This will work
Seriously, what about diesel?
Abe Lincoln
Re: Ziebart Removal [Re: Anonymous] #1976697
12/26/15 07:25 PM
12/26/15 07:25 PM
Spokane Washington
ScottSmith_Harms Offline
Mr Wizzard
Mr Wizzard
Spokane Washington
I second the Steam cleaner as the ultimate factory undercoating removal tool. I like the fact that you don't remove anything but the undercoating and grime, the original paint and primer remains intact unless you actually try to remove it as well (which you can).
With aftermarket Ziebart drilled and squirted into doors and other inaccessible areas dipping the car would be about the only way you'll get rid of it all.
.02
Re: Ziebart Removal [Re: ScottSmith_Harms] #1976707
12/26/15 07:38 PM
12/26/15 07:38 PM
Mesa, Arizona
Mesa, Arizona
.02
iagree Probably the best way doing it at home. I've seen Scott's car first hand and his blaster did a good job getting all the crud off the bottom of his car.
Another option is dustless blasting. (One note. If you go with the dustless blasting option don't do it at home. Creates a big mess that has to be cleaned up. Do it at the vendors location.) We went with that and it took us two days to clean up the mess.
Abe Lincoln
Re: Ziebart Removal [Re: Anonymous] #1978550
12/29/15 02:05 PM
12/29/15 02:05 PM
pa.
dan9 Offline
dan9  Offline
pa.
In the early 70's I was given a test kit for Tectyl. It was made by Ashland Oil part of Valvoline. The guy gave me test metals. One bare and one coated with their product. I was instructed to sit them outside for 2 weeks. Of course the bare metal rusted and the coated sample did not. After 2 weeks he I was instructed to scrape off an area of the coated piece and put it back outside. The area I scraped off never did rust. The claim was that the product penetrated the metal. It sure seemed to. The Ashland Oil rep. mixed up a case in aerosol cans to match my silver 68 RR at the time and gave it to me. As a daily driver in Pa. winters it never did rust where it was applied. He said that Tectyl is chemical name of what was marketed as Ziebart. I recently had a 69 RR that had a very rusty trunk floor, upon removing it I could still see and smell the Ziebart in the frame rails. They were still perfect. I cannot offer any advice on how to remove it if it did penetrate the metal.
