challenger master cylinder
#349758
06/17/09 09:19 AM
06/17/09 09:19 AM
Posts: 863 Pinelands , NJ
joelson6
Pinelands , NJ
WOW. after searching this forum about master cylinders and cap colors, and looking through close to 600 finds on my search, I've drawn this conclusion. Chrysler never made a vehicle with manual brakes, Chrysler never made a vehicle with drum brakes, Chrysler never made a vehicle after 1971 now to my question, I'm restoring my 72 340 Challenger. it's got manual 10" drum brakes. I think I kind of figured out that drum brake master cylinders were left natural and weren't painted. at least that's what I've read on cars built up through 71. I couldn't find anything about 72 and up cars and I couldn't find anything on the cap color and the clip that holds the cap on. was the cap and clip painted or plated? and was the MC painted or natural? If anyone has some info for me, i would much appreciate it. thanks, Greg
Re: challenger master cylinder
[Re: Mastershake340]
#349761
06/17/09 05:12 PM
06/17/09 05:12 PM
Posts: 1,163 NORTHERN VA
THESHAKERPROJECT
NORTHERN VA
I've seen a number of NOS examples that were painted or coated (cap and body) with a dull gray gunmetal-like finish. I'd almost call it a parkerizing or gray phosphate.
I just got a re-built unit from NAPA that had the same dull plating as you pic but mine is for a 71 Challenger with disk brakes (last 3 digits of the casting #187 )and it looked like a NOS piece...was only $26. Was the same gunmetal gray finish used in 71 cars or were they black ??
[Re: THESHAKERPROJECT]
#349762
06/17/09 05:37 PM
06/17/09 05:37 PM
Posts: 8,341 Crook County, ILL
Mastershake340
Crook County, ILL
I've seen a lot of rebuilts that have this same gray finish. I've had a few NOS '71-'74 power disc ones that had this phosphate finish too. I've seen a couple "newer" ones that had gold cad plated caps, these were ones made as replacement parts in the late 70's or early 80's though so that doesn't tell us about what they looked like when the cars were being built. It is my opinion that they started using this finish starting with the '71 model year both for drum and disc. The only exception I know of for sure is the hemi disc brake master cylinder which was a carryover from the '70 model year and was still painted black. Just to confuse the issue though, the few NOS '71-'74 B and E body manual disc brake master cylinders I've had a chance to look at (part number 3580184 with casting number 2229271), were painted black. The juries still out I guess.
#349763
06/17/09 09:06 PM
06/17/09 09:06 PM
joelson6
Pinelands , NJ
thanks for the input guys, i'm more confused now than before, LOL i guess as long as i get the body the right color i have 90% of the battle won. so i guess i'll keep a painted cap & clip and a plated cap & clip and ask the judges which one is correct to them
[Re: FJ5_Fish]
#349766
06/18/09 01:53 PM
06/18/09 01:53 PM
Mastershake340
Crook County, ILL
None of those pics are Mopar drum brake masters - Unless they changed the design after 71.
??? My first picture is an NOS P/N 3461184 master cylinder. It even has the ID tag on the bale wire where you can see the "1184" of the factory part number. This was the brake master cylinder used on most A, and all B and E bodies equipped with drum brakes starting in '71. The second picture was in response to Shakerprojects question on finish on the '71 up disc brake master cylinder. It shows an NOS p/n 3461178 Master cylinder, which has the 3461187 casting number.
[Re: FJ5_Fish]
#349768
06/18/09 02:36 PM
06/18/09 02:36 PM
Posts: 6,906 IL, Aurora
ademon
IL, Aurora
Heres one i picked up a few weeks ago a #3461184 for my 71 demon. no traces of grey paint or coating, under the rubber cap seal its a gold anodize, but top has no trace, wire looks natural. BTW Brad what is the best way to store this master until i use it maybe several years from now when the car gets restored, Pumped new fluid through it and the piston moves freely, should i drain it, take it apart, and coat it with oil? Kits are still at Napa, autozone ect.. Thanks
[Re: ademon]
#349770
06/18/09 02:56 PM
06/18/09 02:56 PM
Mastershake340
Crook County, ILL
Howdy Mike Are you sure that is NOS and not rebuilt? Those protective plugs in the outlets are not the style that Bendix used on their new manufactured master cylinders. If you haven't had it apart, do not take it apart. The factory assembly lube is about as good a protective as your going to find. Otherwise, what ever you do, absolutely under no circumstances even think of using any petroleum based oil in a hydraulic brake part!!! (unless its from a Rolls Royce or an airplane, they use a petroleum based hydraulic fluid). Petroleum based fluids will destroy any EPDM or SBR rubber component internally on that part, and the cap diaphram. I've coated the bore and reservoir of master cylinders I've restored with DOT 5 silicon brake fluid and sprayed the outer bare metal surfaces with WD40 to prevent corrosion. Hope your work schedule allows you to make it to Rolling Meadows some Friday for the cruise, big turnout back at the old abandoned Dominicks site with lots of interesting cars!
#349772
06/18/09 05:15 PM
06/18/09 05:15 PM
Posts: 28,598 Shopping @ HoBo Fright
340SIX
Doc Flappergas's Evil Twin
My 72 340 rally car had drums /drums and a master like pic shows also manual brakes no power streaing and dealer added a/c 340/727 8 3/4" rear with 323:1 gears
[Re: burdar]
#349774
06/19/09 05:02 AM
06/19/09 05:02 AM
joelson6
Pinelands , NJ
Was 72 the last year for front drums on an E-body then?
Not sure, but i can't ever remember seeing a 73 car with drum brakes. I'm gonna keep a look out now.
my car is a 72 challenger. non-rally 340 4 speed, a/c, power steering and manual 10" drum brakes. weird combo huh? but i have the dealer bill of sale and that's how it's listed in it.
Greg
