Re: Opinions on a 422 SB Carb Choice
[Re: ScottSmith_Harms]
#349698
06/17/09 01:37 PM
06/17/09 01:37 PM
Posts: 4,799 ILL
MLR426
ILL
A friend is getting ready to run his fresh 422 (4.00" stroked) 340 on the Dyno. It's got ported W2 econo heads that flow 275 at .550, 295 at .600, pump gas compression (9.60 comp or so) a single plane single 4 cast W2 intake, and a stout (550 ish) hyd. cam. He's got 3 carbs to choose from, a newer rebuilt Holley 4781-5, a freshly rebuilt (stock) 1972 340 Thermoquad, and a new Thunder Series 800 Edlebrock AVS. He plans to run all 3 on the dyno to see the HP differences between them. His planned use is for street with a little strip action. Car is a 340 4 Speed Duster with 3.91 gears. Any guesses on:
Which carb will produce the most HP? Which carb will have the smoothest power curve? How much HP difference will there be from one to the next with no jet changing or special tuning? Which carb will be the most streetable (somewhat subjective I know)?
After you decide what carb your going to use after running the three. Which my vote goes to the 850 as long as you have it jetted right. I bet your best gain will be putting a 2 inch super sucker carb spacer on it, than between carbs. Entry into the intake at the 4 corners of the spacer are important here. Transition,transition. Are they going to advance the cam 2 degerees or straight up ? Sacrifice the top end for the low end torque by advancing the cam. He's running 3.91 gears so he can take more advantage of it during his strip use. I like those 2 figures.
logan426
#349702
06/17/09 01:52 PM
06/17/09 01:52 PM
Posts: 4,799 ILL
MLR426
ILL
Concerning spacers, he's concerned about hood clearance, also hoping to run a stock air cleaner but not the end of the world if he can't. The Holley came with a spacer and the intake, it seems like the natural choice to me as well (4 corner adjusters, etc. pretty nice carb) but again, he's targeting a look closer to stock so it's not at the top of the list right now, actually leaning toward the TQ for use regardless of what the dyno shows. I'm not sure on the cam setup either but top end will likely be the goal since street traction will be wishful thinking at best no matter what. I'll post the numbers when he has it done.
Street traction was going to be an issue regardless with 3.91 gear, so he needs to look at the benefits of running it at the track and using soft compound DOT tires on the street and at the track. That's my 2 cents now I'll rub them together.
logan426
#349704
06/17/09 02:03 PM
06/17/09 02:03 PM
Posts: 4,799 ILL
MLR426
ILL
He will be running a DOT (barely) legal street slick on a stock Rallye wheel.
I assume he is maxing the rim width and tire size. You must be talking the ones with 2 lines in the center of the tire. Your correct barely street legal but they hook like a bear. My bubby has a 500 inch stroker in a 70 dart street car that has a chassis set up for highway hooking and those tires work great.
logan426
[Re: MLR426]
#349705
06/17/09 02:27 PM
06/17/09 02:27 PM
Posts: 42,714 Spokane Washington
ScottSmith_Harms
Mr Wizzard
Mr Wizzard
Spokane Washington
Yes, stock width 14.00" Rallye rims
#349706
06/17/09 02:48 PM
06/17/09 02:48 PM
Posts: 5,484 SoCal
Brian Hafliger
SoCal
Tell Stew to scrounge up a 950HP carb and dyno that carb against all those others...it will make at least 12-15HP more and probably 18-20 more. Jet it 78-78 with PV's or 86-86 without.
Brian Hafliger
[Re: Brian Hafliger]
#349707
06/17/09 03:51 PM
06/17/09 03:51 PM
Posts: 16,123 Grand Haven, MI
patrick
Grand Haven, MI
a demon sizzler prepped big t-quad would be interesting to see on the motor.
mostly street use, limited strip use, I'd probably vote for one of the carters, ideally a large tquad.
[Re: mopar dave]
#349709
06/17/09 04:39 PM
06/17/09 04:39 PM
Posts: 5,484 SoCal
Brian Hafliger
SoCal
what do you think the jetting would look like if he were to use a 850dp?
J/K...
