I lost a second. #349076
06/16/09 04:14 PM
06/16/09 04:14 PM
Lenox, MI
gj69charger Offline OP
Lenox, MI
Somewhere I lost a second in my 1/4 mile times. I've always run 10.80s and now I'm running 11.80s-12.00s. I’m lost a tenth in my 60ft., a half in the 1/8 and a second in the ¼. I initially thought it was from an E85 conversion I did this year. However when I switched back it still ran the same. Motor runs fine, checked compression and it’s good. I had some work done on the rear end, but doesn’t seem to be binding. The only thing left is the trans. Any ideas would be greatly appreciated. Greg
Re: I lost a second. [Re: gj69charger] #349077
06/16/09 04:33 PM
06/16/09 04:33 PM
Laredo, Texas USA
hugo Offline
hugo  Offline
Laredo, Texas USA
Its probably your trans or converter going out.
Re: I lost a second. [Re: gj69charger] #349078
06/16/09 04:35 PM
06/16/09 04:35 PM
nc
E
emarine01 Offline
emarine01  Offline
E
nc
Wow tuff question on where to start check gear ratio maybe someone else is running your gear set
Re: I lost a second. [Re: gj69charger] #349079
06/16/09 04:45 PM
06/16/09 04:45 PM
MR_P_BODY Offline
MR_P_BODY  Offline
Does the converter still flash the same?
Re: I lost a second. [Re: MR_P_BODY] #349080
06/16/09 04:46 PM
06/16/09 04:46 PM
Worst Weather USA
493_DART Offline
493_DART  Offline
Worst Weather USA
+1 on converter
Re: I lost a second. [Re: 493_DART] #349081
06/16/09 05:09 PM
06/16/09 05:09 PM
SW Ohio
cgall Offline
cgall  Offline
SW Ohio
Check plugs, wires, and dist. cap. Check rotor button. Test fuel pump volume. If all is well, pull front cover and check cam timing. You are losing ET all the way down the track.
Re: I lost a second. [Re: cgall] #349082
06/16/09 05:28 PM
06/16/09 05:28 PM
Greentown Indiana
moparmxz Offline
moparmxz  Offline
Greentown Indiana
Another vote for the converter.
Randy Brough 1967 440 Dart S/P 6.37 106mph best eighth 3150 lbs
Re: I lost a second. [Re: gj69charger] #349083
06/16/09 05:32 PM
06/16/09 05:32 PM
Val-haul-ass... eventually
BradH Offline
BradH  Offline
If it's a flat-tappet cam, I'd check that to make sure you're not losing lobes.
Re: I lost a second. [Re: BradH] #349084
06/16/09 05:42 PM
06/16/09 05:42 PM
Longview, Texas
marvo451 Offline
marvo451  Offline
Longview, Texas
Converter, drop the transmission pan and I bet it looks like a junk metal sale.
Re: I lost a second. [Re: gj69charger] #349085
06/16/09 06:00 PM
06/16/09 06:00 PM
usa
hot67cuda Offline
hot67cuda  Offline
usa
Valve springs
Re: I lost a second. [Re: hot67cuda] #349086
06/16/09 06:31 PM
06/16/09 06:31 PM
Minnesota
Barnstorm Offline
Barnstorm  Offline
Minnesota
Do the EZ stuff first. Make sure the brakes are not dragging. Wierd gremlins breed in the off season.
The little old lady from Pasadena is back!
Re: I lost a second. [Re: MR_P_BODY] #349087
06/16/09 06:59 PM
06/16/09 06:59 PM
Lenox, MI
Lenox, MI
Yes it is.
Re: I lost a second. [Re: gj69charger] #349088
06/16/09 07:03 PM
06/16/09 07:03 PM
Sk. Canada
RemCharger Offline
RemCharger  Offline
Sk. Canada
is the mph the same?
Re: I lost a second. [Re: RemCharger] #349089
06/16/09 07:11 PM
06/16/09 07:11 PM
Lenox, MI
Lenox, MI
No. It's off about 10mph.
Re: I lost a second. [Re: gj69charger] #349090
06/16/09 07:34 PM
06/16/09 07:34 PM
robin hood country
deaks Offline
deaks  Offline
robin hood country
What happens to the converter internally when it starts to fail.
Mick
69 Dart GTS 440 mopar .590 cam, Edelbrock heads, 3200#
best et 6.45, 106.78, 10.14, 132.88 mph, 1.47 60ft
best 60ft 1.36
Re: I lost a second. [Re: gj69charger] #349091
06/16/09 07:38 PM
06/16/09 07:38 PM
MR_P_BODY Offline
MR_P_BODY  Offline
Are your RPM's up higher at the traps
Re: I lost a second. [Re: MR_P_BODY] #349092
06/16/09 07:45 PM
06/16/09 07:45 PM
Lenox, MI
Lenox, MI
I can't say for sure, but I think so. It seems like I was hitting my shift points a lot earlier. The only way I can describe it is like I'm dragging an anchor. Working hard but not going anywhere.
Re: I lost a second. [Re: gj69charger] #349093
06/16/09 09:24 PM
06/16/09 09:24 PM
Illinois
Mopar_Ray Offline
Mopar_Ray  Offline
Illinois
Rookie question, have you checked electrical stuff? rotor and cap? MI winters gotta be hard on that stuff.
Re: I lost a second. [Re: Mopar_Ray] #349094
06/16/09 10:22 PM
06/16/09 10:22 PM
Ontario, Canada
Dodgem Offline
Dodgem  Offline
Ontario, Canada
I was once off 7 tenths in the spring and forgot I had backed timing off for cool fall air street driving. was at 29 back to 38 and it went from 12.2 to 11.5.
Just this week I tried throttle stopping to the twelves went back to full throttle and 11.21 [Edited by Moparts - Keep it clean]?? oh timing went from 35 to 40 and 10.82!!
It happens
backing plates on rear axles rotating and binding up the brakes?
Re: I lost a second. [Re: Barnstorm] #349095
06/16/09 10:45 PM
06/16/09 10:45 PM
ohio
mike67net Offline
mopar addict
mike67net  Offline
mopar addict
ohio
so i'll ask a really stupid question. Did you check to make sure you are getting WOT with the pedal to the floor?
