Loose Flex Plate bolts
#348841
06/16/09 11:53 AM
06/16/09 11:53 AM
I have 727 trans behind a 440 bored and stroked to 500 in an Altered. The problem I have is the flex plate bolts keep coming loose, and it looks like its trying to pull the bolts through the flex plate. I have a TCS converter with a steal stater and 3800 stall. I had the same problem with a mild 440 on the same trans. You can see where the crankshaft-flex plate bolts have been touching the converter. Is it possible the converter is "Ballooning"? I have the engine out right now because of Rod bearing failure, could the two be related? Any Ideas????
Re: Loose Flex Plate bolts
[Re: WILD BILL]
#348843
06/16/09 12:20 PM
06/16/09 12:20 PM
Yes I tried Red Loctite it was o.k for a few passes then started coming loose again
[Re: BRawls]
#348846
06/16/09 01:10 PM
06/16/09 01:10 PM
That's a good idea using studs
#348847
06/16/09 04:01 PM
06/16/09 04:01 PM
Posts: 25,914 Rio Linda, CA
John_Kunkel
Rio Linda, CA
Using stud mount Loc-Tite doesn't mean studs were used (no room for them) it only means a stronger Loc-Tite product was used.
There have been discussions before where some installations suffered from frequent loosening of converter bolts, drilling for safety is one recommended fix.
#348848
06/16/09 04:18 PM
06/16/09 04:18 PM
Posts: 13,380 Marion, South Carolina [><]
an8sec70cuda
You said you can see where the flexplate-crank bolts are hitting the converter cover...you may have a problem there that I've seen before. Some converters need a recess cut on the cover to keep those bolts from hitting. If they hit, then the flexplate-converter bolts have to pull the plate to the converter causing a bind. This can cause the bolts to loosen up over time. CHIP
[Re: an8sec70cuda]
#348849
06/16/09 05:49 PM
06/16/09 05:49 PM
Posts: 1,012 indiana
mcmopars
indiana
with converter in place,what is an unacceptable gap between the flex plate and the converter?
