Re: Camshaft too tight.
[Re: royt440]
#348612
06/16/09 01:03 AM
06/16/09 01:03 AM
RapidRobert
a brake hone w fine stones for cam journals 1,2,4,5 & fab an extension for your hone to reach #3
[Re: goldmember]
#348614
06/16/09 01:41 AM
06/16/09 01:41 AM
Posts: 3,908 Oregon
hooziewhatsit
Is this caused by having one (or more) of the bearings slightly out of alignment when it was installed? So in effect, it's squeezing the cam?
If so, could it be fixed by replacing the (errant) bearings again, and hoping they go in correctly?
(Curious, so I'll know what to do if I ever see it in the future)
-Dave
[Re: hooziewhatsit]
#348615
06/16/09 01:52 AM
06/16/09 01:52 AM
Posts: 4,501 Gainesville,FL
goldmember
Gainesville,FL
Could be the bearing bores are not aligned,the bore(s) are not correct diameter,bearing out of spec,etc. You could replace a single bearing,may not fix the problem. You can install the cam,rotate the cam,remove the cam and inspect the bearings. You will see the problem area. If you don't feel confortable removing the tight spot(s) just have your shop do it.
[Re: royt440]
#348617
06/16/09 07:10 AM
06/16/09 07:10 AM
Posts: 12,675 Columbia, CT
moper
Columbia, CT
Do not use a hone or paper, or any abrasive on the bearings... As wa said, the technique is to use a sharp blade to scrape away the high spots that make the cam hard to turn. That's it. Not hog the hole out until it fits. By installing the cam with light oil (I use WD40) and turning it you will see the tight spots as shiney areas. Then I use a single edge razor blade (KD Tools I think used to make a fancy cam bearing scraper tool) to scrape the high sprots and remove a very thin layer just from that spot(s). When I can tunr the cam by hand with two fingers (little effort) it's done.
[Re: moper]
#348618
06/16/09 09:06 AM
06/16/09 09:06 AM
Posts: 7,506 Az
Crizila
Az
Before you do anything with the cam bearings, put the cam in some V blocks and check it for straightness. Shouldn't be out more tham .003". If your machine shop is on the ball they would have a mock-up cam that they ran through the bearings to make sure you didn't have this problem.
Fastest 300
[Re: royt440]
#348619
06/16/09 09:45 AM
06/16/09 09:45 AM
Posts: 8,911 Ontario, Canada
Stanton
Don't question me!
Don't question me!
Ontario, Canada
core shift, cocked bearings, bent cam ... all BS !! This is one of the most common big block problems and for the REAL lowdown read this: http://www.musclemotorsracing.com/muscle-mike-blogShort of $1000 fix, I'd be going in to the tight bearing(s) with a hone and hoping to hell they don't need much taken off.
[Re: Crizila]
#348623
06/16/09 01:56 PM
06/16/09 01:56 PM
Posts: 8,716 Baltimore/Denver
64Post
Baltimore/Denver
Amen to that!
How does something like that get out the door unchecked?
Re: Camshaft too tight. - the REAL story...
[Re: Rick_Ehrenberg]
#348624
06/16/09 02:53 PM
06/16/09 02:53 PM
Posts: 5,314 Carstairs, Alberta, Canada
dave571
This will blow your mind but it is FACT.
The factory always did a halfass job boring the cam tunnel. They didn't really care...because the OEM cam bearings were WAY undersized, they then line-bored (precision) the BEARINGS.
Now you know why all the old MP manuals suggest not changing the cam bearings unless absolutely necessary!
About all you can do is use a bearing knife or an old cam with sharp grooves to act as a reamer.
Rick
Yup.
Most machine shops will clearance them with a cam that has been cut for this.
[Re: dave571]
#348625
06/16/09 03:00 PM
06/16/09 03:00 PM
Posts: 3,698 NE Oklahoma
Von
NE Oklahoma
I have a 72 440 block that is a total mess as far as the cam bearings go. When I first got the car the block was in (1988) I tried to swap cams. 2 of the cam bearings were spun. Finally got 2 bearings back in the dang thing...after a few stitches due to cutting a finger on the bearings. I had to pound the cam into the last set of bearings. It was so tight the motor would barely turn over. Once it did light, it clearanced itself pretty quickly. When I tore that motor down and re did it, had new bearings put in. Same thing as before, cam was way tight. We screwed a grade 8 bolt in the end of the cam, chucked the bolt in a drill and tried to loosen it up. Bad idea, broke the bolt off in the cam. Had to take a stock cam and groove it to ream the bearings. No problems after that, oil pressure was rock solid. After 1k miles and a couple dozen passes, pulled the motor down, everything looked fine. Last time around with this block, took it to a machine shop and asked if they correct the journals. I was told no problem, he could use the line hone to fix the journals. Well, he didnt. He scraped the bearings to fit my cam. No biggie, but I paid to have the journals honed, not the bearings.
72 RR, Pump gas 440, 452s, 3800 lbs, Corked, ET Radials,. 11.33@117.72.
Same car, bone stock 346s, 9.5 comp, baby solid. 12.24@110.
[Re: Von]
#348627
06/16/09 03:20 PM
06/16/09 03:20 PM
Posts: 30,491 Florida STAYcation
dOc …
The village idiot's idiot
Florida STAYcation
HOW did you get the cam in-there to begin with ? ...
ALL THIS here on this topic confirms what I have thought for years. NOT to "boil" a block(thus ruining the cam bearings) .. to clean-it myself .. or - at the most - to whirly-bird it.
