wilwood rear brake kit #348461
06/15/09 11:14 PM
06/15/09 11:14 PM
Charleston
sixpackgut Offline OP
Drag Week Mod Champion
Charleston
will a wilwood rear brake kit from a 8.75 bolt on a Dana? possible trade in the works
Re: wilwood rear brake kit [Re: sixpackgut] #348462
06/15/09 11:17 PM
06/15/09 11:17 PM
W. Kentucky
justinp61 Offline
justinp61  Offline
W. Kentucky
IIRC the kit I have on my Dart was listed for a 8 3/4 and Dana.
Re: wilwood rear brake kit [Re: justinp61] #348463
06/15/09 11:19 PM
06/15/09 11:19 PM
Charleston
Charleston
oh boy
Re: wilwood rear brake kit [Re: sixpackgut] #348464
06/15/09 11:33 PM
06/15/09 11:33 PM
W. Kentucky
justinp61 Offline
justinp61  Offline
W. Kentucky
I checked Summit, the same kits fit both .
Re: wilwood rear brake kit [Re: justinp61] #348465
06/15/09 11:45 PM
06/15/09 11:45 PM
SO. CAL.
70blackfish Offline
70blackfish  Offline
SO. CAL.
should be the same
when I switched from rear drum to disc, it was 50 pounds lighter,
and its in a good place to loose some weight
Re: wilwood rear brake kit [Re: 70blackfish] #348466
06/16/09 08:15 AM
06/16/09 08:15 AM
Houston, Texas
TheOtherDodge Offline
Houston, Texas
Yes, knowledge through experience!
Re: wilwood rear brake kit [Re: TheOtherDodge] #348467
06/16/09 10:20 AM
06/16/09 10:20 AM
Riverside, California
Lil Demon Offline
Lil Demon  Offline
Ray - you should be fine. Do the deal.
Re: wilwood rear brake kit [Re: sixpackgut] #348468
06/16/09 11:00 AM
06/16/09 11:00 AM
Greenville, South Carolina
BBLM23 Offline
BBLM23  Offline
Just have to make sure the bearings are the same...
Walter
1969 Dart Swinger w/ARC Pump Gas 493 B1/BS 10.18 at 130mph
Racing Pro in street trim.
1981 Aries ARC 548 B1 8.88 at 147mph (footbraking)
1996 Ram 2500 V10 16.52 at 80mph
1981 Reliant 400
Re: wilwood rear brake kit [Re: BBLM23] #348469
06/16/09 11:24 AM
06/16/09 11:24 AM
Q
Quicktree Offline
Quicktree  Offline
Q
the bearings?
Re: wilwood rear brake kit [Re: Quicktree] #348470
06/16/09 11:50 AM
06/16/09 11:50 AM
new jersey usa
11secdart Offline
11secdart  Offline
new jersey usa
I did the swap a few yers ago and saved 50 lbs also. I bought the narrowed 83/4 out of a friends Dart when he went to a Dana, I bought the kit for an 83/4 not knowing they put MW ends on the rear so I had to have a machinist/friend machine the caliper bracket to fit over the bearings. I also had to have him open up the holes in the hats to fit 5/8 studs.
68 Dart 410 / 904
92 D150 original owner
21 Ram 1500 Quad Cab, Big Horn , Hemi ,4x4
23 Audi Q5
16 Honda HRV
Re: wilwood rear brake kit [Re: Quicktree] #348471
06/16/09 12:10 PM
06/16/09 12:10 PM
BBLM23 Offline
BBLM23  Offline
the bearings?
The Wilwood kits are based on what bearings are on the axles.
8-3/4" Mopar / Dana 60 (Green Bearing) 2.36" 140-0260
8-3/4" Mopar / Dana 60 (Green Bearing-Snap Ring)
2.36" 140-5255
2.50" 140-8853
Walter
1981 Reliant 400
Re: wilwood rear brake kit [Re: BBLM23] #348472
06/16/09 12:19 PM
06/16/09 12:19 PM
Laredo, Texas USA
hugo Offline
hugo  Offline
Laredo, Texas USA
I added a wilwood kit to my dana. All I had to do is change my bearings to the green bearing. Just look at the sizes and you'll be fine. I they dont fit just get the right bearing and they will fit.
Re: wilwood rear brake kit [Re: hugo] #348473
06/16/09 12:31 PM
06/16/09 12:31 PM
Charleston
Charleston
ok, thanks for the info
Re: wilwood rear brake kit [Re: sixpackgut] #348474
06/16/09 01:15 PM
06/16/09 01:15 PM
SO. CAL.
70blackfish Offline
70blackfish  Offline
SO. CAL.
thats right, I had to use the green bearings with snap ring,
the aerospace kit uses that type.
