Re: wilwood rear brake kit
[Re: justinp61]
#348465
06/15/09 11:45 PM
06/15/09 11:45 PM
Posts: 4,152 SO. CAL.
70blackfish
SO. CAL.
should be the same when I switched from rear drum to disc, it was 50 pounds lighter, and its in a good place to loose some weight
[Re: sixpackgut]
#348468
06/16/09 11:00 AM
06/16/09 11:00 AM
Posts: 2,273 Greenville, South Carolina
BBLM23
Just have to make sure the bearings are the same...
Walter 1969 Dart Swinger w/ARC Pump Gas 493 B1/BS 10.18 at 130mph Racing Pro in street trim. 1981 Aries ARC 548 B1 8.88 at 147mph (footbraking) 1996 Ram 2500 V10 16.52 at 80mph 1981 Reliant 400
[Re: BBLM23]
#348469
06/16/09 11:24 AM
06/16/09 11:24 AM
Quicktree
the bearings?
[Re: Quicktree]
#348470
06/16/09 11:50 AM
06/16/09 11:50 AM
Posts: 4,963 new jersey usa
11secdart
new jersey usa
I did the swap a few yers ago and saved 50 lbs also. I bought the narrowed 83/4 out of a friends Dart when he went to a Dana, I bought the kit for an 83/4 not knowing they put MW ends on the rear so I had to have a machinist/friend machine the caliper bracket to fit over the bearings. I also had to have him open up the holes in the hats to fit 5/8 studs.
