chassis gurus #348410
06/15/09 09:58 PM
06/15/09 09:58 PM
Way North Illinois
JandJ_Racing Offline OP
Way North Illinois
I think I need to lower the ladder bars. They are between 0 and 1 degree down in front. I have 13.2 pounds in the 31x13 slicks. It looks like the tires are getting hit to hard the way the face of the slick is "puckered". Any suggestions.
Re: chassis gurus [Re: JandJ_Racing] #348411
06/15/09 10:05 PM
06/15/09 10:05 PM
Way North Illinois
Way North Illinois
A close up of the tire
Re: chassis gurus [Re: JandJ_Racing] #348412
06/15/09 10:27 PM
06/15/09 10:27 PM
Lebanon,IN
mr2performance Offline
Lebanon,IN
more air, tighten the extension to start,Mike
MR2PERFORMANCE RACE CARS 765 483 9371
Re: chassis gurus [Re: JandJ_Racing] #348413
06/15/09 10:28 PM
06/15/09 10:28 PM
Lebanon,IN
Lebanon,IN
whats it weigh, what gear?
Re: chassis gurus [Re: mr2performance] #348414
06/15/09 10:41 PM
06/15/09 10:41 PM
Way North Illinois
Way North Illinois
3525lbs
4.30 dana
Re: chassis gurus [Re: JandJ_Racing] #348415
06/15/09 10:44 PM
06/15/09 10:44 PM
Way North Illinois
Way North Illinois
I have the extension about as tight as you can for greatlakes gragway. The track has so many bumps in it. I had the double adj. Strange shocks tighter but I didnt like when you could read the name on the door from the starting line at the 1000 ft cone.
Re: chassis gurus [Re: JandJ_Racing] #348416
06/15/09 10:46 PM
06/15/09 10:46 PM
Newark, OH
Hunted Duck Offline
Hunted Duck  Offline
Newark, OH
Do you have single or double adjustable shocks? Doesn't look to far off to me. I would tighten the extension as well, unless you are already up there. How old are the shocks?
Re: chassis gurus [Re: Hunted Duck] #348417
06/15/09 10:49 PM
06/15/09 10:49 PM
Way North Illinois
Way North Illinois
Shocks are double adj. Strange whent thru them last winter. I can run them tighter at goodtracks but the picture is from a marginal track and thay are about as tight as I feel is safe. The track has bumps down track and if the shocks are to tight they dont recover well over the bumps and it turns into a scary ride.
Re: chassis gurus [Re: JandJ_Racing] #348418
06/15/09 10:55 PM
06/15/09 10:55 PM
Newark, OH
Hunted Duck Offline
Hunted Duck  Offline
Newark, OH
You could definitly drop them down a hole. Do you have the 3 or 5 hole brakets? You could also leave the bars where they are and take alittle pinion angle out? Just a thought.
Re: chassis gurus [Re: Hunted Duck] #348419
06/15/09 10:59 PM
06/15/09 10:59 PM
Way North Illinois
Way North Illinois
old picture but 5 hole.
Re: chassis gurus [Re: JandJ_Racing] #348420
06/15/09 11:00 PM
06/15/09 11:00 PM
MR_P_BODY Offline
MR_P_BODY  Offline
Air up the tire
Re: chassis gurus [Re: JandJ_Racing] #348421
06/15/09 11:02 PM
06/15/09 11:02 PM
Way North Illinois
Way North Illinois
The bars are in the secind hole from the top and that is between 0 and 1 degree down. It whent 1.37 in the 60 in that picture. Just not wild about the tir puckering like that. I thought that maybe a slightly softer hit that is applied a little longer might be better and maybe weight transfer better. The car sucks whenit dosent weight transfer. losses a tenth on the starting line.
Re: chassis gurus [Re: MR_P_BODY] #348422
06/15/09 11:24 PM
06/15/09 11:24 PM
Canton, Ohio
Sport440 Offline
Sport440  Offline
Canton, Ohio
Air up the tire
all else looks good to me!
Re: chassis gurus [Re: Sport440] #348423
06/15/09 11:49 PM
06/15/09 11:49 PM
Santa Rosa,CA USA
67dodgeracer Offline
Santa Rosa,CA USA
Yep,try adding a lb.How many passes are you getting out of those sidewalls?
Re: chassis gurus [Re: 67dodgeracer] #348424
06/16/09 12:41 AM
06/16/09 12:41 AM
Central Ohio, USA
Bigbeep Offline
Bigbeep  Offline
Central Ohio, USA
It doesn't look to far off to me. I think I would creep up on the tire pressure before adjusting anything else. According to Dave Morgan's door slammer book, your car is working pretty good. He actually has a pic of a cuda doing the same thing and he states that this car is on a good pass.
