stroker 360 with factory rods? why not? #348281
06/15/09 07:16 PM
06/15/09 07:16 PM
warfordsburg, PA
dirt Offline OP
dirt  Offline OP
warfordsburg, PA
would it be safe using the factory rods with a 4" crank in a 360?
i see most places sell rods in the stroker kits but i would think the factory rods would handle a fair amount of power. were the 360 rods any different than the 340?
Re: stroker 360 with factory rods? [Re: dirt] #348282
06/15/09 07:37 PM
06/15/09 07:37 PM
MR_P_BODY Offline
MR_P_BODY  Offline
Small block rods are 6.123" (stock)
Re: stroker 360 with factory rods? why not? [Re: dirt] #348283
06/15/09 08:20 PM
06/15/09 08:20 PM
Houston, Texas
TheOtherDodge Offline
Houston, Texas
Your question was "would it be safe". That all depends on the power level you want. The more power the more work you will have to do to the rods like getting them shot peaned, side beamed and good bolts. When you get good bolts you will have to have them resized. So when everything is said and done you have a decent amount of money in a stock rod. Good H-beam rods are $500 and they are stronger and lighter.
Re: stroker 360 with factory rods? why not? [Re: TheOtherDodge] #348284
06/15/09 08:26 PM
06/15/09 08:26 PM
warfordsburg, PA
dirt Offline OP
dirt  Offline OP
warfordsburg, PA
I had everything checked out when i originally built the motor 14,000 miles ago in my 360. i was running edelbrock heads on it then. i had a spark plug come apart and mess up the piston.
so would it be safe to use the rods and bolts over if they didnt look messed up? Its a street car and i dont figure on running the crap out of it at high RPM's. i used to shift the thing at 6700 but figure i wont need to wind it up as much with a stroker crank. I like the idea of torque at a lower RPM
Re: stroker 360 with factory rods? why not? [Re: dirt] #348285
06/15/09 08:35 PM
06/15/09 08:35 PM
Q
Quicktree Offline
Quicktree  Offline
Q
why would even want to risk it? H beam rods are pretty cheap insurance and not that costly. if you can't afford to do it right the first time you sure can't afford to do it twice.
Re: stroker 360 with factory rods? why not? [Re: Quicktree] #348286
06/15/09 08:56 PM
06/15/09 08:56 PM
nc
E
emarine01 Offline
emarine01  Offline
E
nc
If you can afford the h beams do it, I would save some where else on the build and use good rods, you can shop around some and do better than 500, Even though stroker rmps are lower the piston speed is way up there and puts more strain on the rods, there are the bushed I beam rods also , the big end on I beams require less grinding on the bottom of the cyls and are stronger than stock
Re: stroker 360 with factory rods? why not? [Re: TheOtherDodge] #348287
06/15/09 09:04 PM
06/15/09 09:04 PM
MR_P_BODY Offline
MR_P_BODY  Offline
I agree with the others a H-beam rod is cheap now days.
I had a set of the best production small block rods
in my 340(viper rods) and I did alot of work to them
and after about 2 years of racing I had one break in
half... just not worth it when you figure the cost of
the heads and crank or anything else that may get damaged
if one breaks. By the way, how old are the ones you
have 15 years old(guess) not worth it........ JMO
Re: stroker 360 with factory rods? why not? [Re: MR_P_BODY] #348288
06/15/09 09:16 PM
06/15/09 09:16 PM
warfordsburg, PA
dirt Offline OP
dirt  Offline OP
warfordsburg, PA
The actual motor was a 78. i had it built in 2000. put 14000 miles on it and the spark plug came apart and messed up the piston a couple months ago.
after looking at the price of everything i almost think i should just build the 440 i have for it, not much difference in price. i just dont wan to cut the inner fenders to get a good set of headers on it
Re: stroker 360 with factory rods? why not? [Re: dirt] #348289
06/15/09 09:34 PM
06/15/09 09:34 PM
Left Coast
BobR Offline
BobR  Offline
Left Coast
You can always get headers made but it will cost a lot more. Rods are the one area you don't want to cheap out on.
Re: stroker 360 with factory rods? why not? [Re: BobR] #348290
06/16/09 07:35 AM
06/16/09 07:35 AM
Grand Haven, MI
patrick Offline
patrick  Offline
Grand Haven, MI
if the rods were resized with ARP bolts, and you keep the revs under ~6k, I'd reuse stock rods in a heartbeat. I guess I'd trust them more than some of the cheaper offshored crap (i.e. eagle SIR's, etc)
2017 Grand Cherokee Overland
Re: stroker 360 with factory rods? why not? [Re: dirt] #348291
06/16/09 08:10 AM
06/16/09 08:10 AM
Indy
FlyFish Offline
FlyFish  Offline
Indy
I would go with Scat I-beams, they are lighter than H-beams, cheap, strong (rated to 650 hp), should clear the block without grinding, and should not need any heavy metal in the crank to balance the assembly (or at least my set up didn't). FWIW, A lot of the guys I talked to with H-beams and strokers had to put a few slugs of heavy metal in the crank to balance the assembly...that just extra money thrown away if its just a street car.
67 Barracuda street car, 408, e85, 1.38 60', 6.44 @105.9 in the 1/8 mile, 10.19 @130.5 in the 1/4...so far....
Re: stroker 360 with factory rods? why not? [Re: FlyFish] #348292
06/16/09 08:18 AM
06/16/09 08:18 AM
Columbia, CT
moper Offline
moper  Offline
Columbia, CT
Like Patrick. I use them for under 6K redline engines, and I dont trust the cheaper imports. I dont do the beams. They get shot peened, bushed, ARP bolts, and re-sized and they cost about $320/set ready to assemble. The next step up for me is the Eagle Hbeams, which may need fixing, then the better I beam rods. As most of these engines make peak power under 6K, they are fine.
Re: stroker 360 with factory rods? why not? [Re: FlyFish] #348293
06/16/09 11:31 AM
06/16/09 11:31 AM
north west LA
W
W2DODGE Offline
W2DODGE  Offline
W
north west LA
I would also recomend the scat I-beam rods if you are trying to keep costs down
Re: stroker 360 with factory rods? why not? [Re: emarine01] #348294
06/16/09 11:51 AM
06/16/09 11:51 AM
Oakland, MI
dizuster Offline
dizuster  Offline
Oakland, MI
Piston speed is driven by RPM.
3.58" stroke at 6700RPM = 4000 Feet per min.
4" stroke at 6,000 RPM = 4000 Feet Per min.
Rod doesn't know any difference except it gets less cycles at the same speed. Also, the piston is lighter in a stroker motor (pin's up higher), so it will actually end up with less strain on the rod.
Nobody would question 6,700 in a 360, so why does everyone worry about 6,000 in a 408"
The head will choke and be done making power at the same piston speed regardless of RPM.
340 and 360 rods are different. As I remember 340 are full floating, and 360 are press fit...
(someone feel free to correct me if I have those backwards)
Re: stroker 360 with factory rods? why not? [Re: dizuster] #348295
06/16/09 12:10 PM
06/16/09 12:10 PM
nc
E
emarine01 Offline
emarine01  Offline
E
nc
All the 360s Ive been in had pressed pins , If you are upgrading to a stroker you may have to bore some and may choose forged pistons . this may make up the weight of the short stroker skirt in most cases , The cost of fixing stock rods is too close to the purchase price of a new set of better rods
Re: stroker 360 with factory rods? why not? [Re: emarine01] #348296
06/16/09 01:13 PM
06/16/09 01:13 PM
warfordsburg, PA
dirt Offline OP
dirt  Offline OP
warfordsburg, PA
I was think that i allready fixed up the stock rods and since have only put 14,000 miles on them with only 1 trip to the track, so it hardly ever seen over 5000 RPM, just the one trip to the track it was s shifted at 6700.
i wouldnt see why the rods would need reworked allready. I dont plan on running it in high RPM's its only a street car that i like to have some fun with.
like the other guy posted if 6700 is ok with the stock stroke then is 6000 very different with a 4" stroke?
I also have a 340 that i could do the same thing to but i was thinking that the rods were lighter and may not be as strong? how much of an advantage is it to have floating piston pins?
any thoughts?
Re: stroker 360 with factory rods? why not? [Re: patrick] #348297
06/16/09 01:17 PM
06/16/09 01:17 PM
Portage,michigan
B3422W5 Offline
B3422W5  Offline
Portage,michigan
the Eagle SIR rods are about the only rod i WOULDNT use in a stroker build thats going to make any steam at all, other than the stock rods.Those and the stock rods i would stay away from for sure.
As others have said, put a good rod in it
Best so far, low 10.30’s 1/4
1.41 best 60 foot
6.56 at 104.17
Re: stroker 360 with factory rods? why not? [Re: B3422W5] #348298
06/16/09 03:10 PM
06/16/09 03:10 PM
warfordsburg, PA
dirt Offline OP
dirt  Offline OP
warfordsburg, PA
so let me make sure i understand,
the smallblocks i have always ran never had any problem at 6700 and i figure the stroker would see the same piston speed at 6000 so wouldnt it be the same?
if the rods were good in the 360 at 6700 shouldnt they be the same just as good at 6000 in a stroker?
i am not arguing i just want to understand why this is not true?
Re: stroker 360 with factory rods? why not? [Re: dirt] #348299
06/16/09 03:24 PM
06/16/09 03:24 PM
Kalispell Mt.
HotRodDave Offline
HotRodDave  Offline
Kalispell Mt.
If you run stock rods you will need to externally balance it or buy expensive mallory to internally balance it. I would buy the SCAT I beam rods also because they are so much lighter it will make your engine rev way easier and be easier on the crank. The lighter weight also helps get you engine to the power produceing part of the rpm range quicker. For around $300 they are well worth the money. I have a set in my 318 along with some light weight pistons and WOW does it rev up quick! I even have a stock cam and heads on it.
Re: stroker 360 with factory rods? why not? [Re: dirt] #348300
06/16/09 03:28 PM
06/16/09 03:28 PM
nc
E
emarine01 Offline
emarine01  Offline
E
nc
At face value it all sounds right but there are other factors that come to play , the starting and stoping forces are greater as the dwell time at the top and bottom of the stroke change and the rod angle changes with the longer stroke, some say it makes no diff and others say it does ,Thats why the better rod is worth the bucks cause I think nobody knows for sure
