Re: stroker 360 with factory rods? why not?
[Re: TheOtherDodge]
#348287
06/15/09 09:04 PM
06/15/09 09:04 PM
Posts: 52,972 Romeo MI
MR_P_BODY
I agree with the others a H-beam rod is cheap now days. I had a set of the best production small block rods in my 340(viper rods) and I did alot of work to them and after about 2 years of racing I had one break in half... just not worth it when you figure the cost of the heads and crank or anything else that may get damaged if one breaks. By the way, how old are the ones you have 15 years old(guess) not worth it........ JMO
[Re: dirt]
#348289
06/15/09 09:34 PM
06/15/09 09:34 PM
Posts: 8,165 Left Coast
BobR
Left Coast
The actual motor was a 78. i had it built in 2000. put 14000 miles on it and the spark plug came apart and messed up the piston a couple months ago. after looking at the price of everything i almost think i should just build the 440 i have for it, not much difference in price. i just dont wan to cut the inner fenders to get a good set of headers on it
You can always get headers made but it will cost a lot more. Rods are the one area you don't want to cheap out on.
[Re: BobR]
#348290
06/16/09 07:35 AM
06/16/09 07:35 AM
Posts: 16,123 Grand Haven, MI
patrick
Grand Haven, MI
if the rods were resized with ARP bolts, and you keep the revs under ~6k, I'd reuse stock rods in a heartbeat. I guess I'd trust them more than some of the cheaper offshored crap (i.e. eagle SIR's, etc)
[Re: dirt]
#348291
06/16/09 08:10 AM
06/16/09 08:10 AM
Posts: 1,178 Indy
FlyFish
Indy
I would go with Scat I-beams, they are lighter than H-beams, cheap, strong (rated to 650 hp), should clear the block without grinding, and should not need any heavy metal in the crank to balance the assembly (or at least my set up didn't). FWIW, A lot of the guys I talked to with H-beams and strokers had to put a few slugs of heavy metal in the crank to balance the assembly...that just extra money thrown away if its just a street car.
67 Barracuda street car, 408, e85, 1.38 60', 6.44 @105.9 in the 1/8 mile, 10.19 @130.5 in the 1/4...so far....
[Re: FlyFish]
#348292
06/16/09 08:18 AM
06/16/09 08:18 AM
Posts: 12,675 Columbia, CT
moper
Columbia, CT
Like Patrick. I use them for under 6K redline engines, and I dont trust the cheaper imports. I dont do the beams. They get shot peened, bushed, ARP bolts, and re-sized and they cost about $320/set ready to assemble. The next step up for me is the Eagle Hbeams, which may need fixing, then the better I beam rods. As most of these engines make peak power under 6K, they are fine.
[Re: FlyFish]
#348293
06/16/09 11:31 AM
06/16/09 11:31 AM
Posts: 799 north west LA
W2DODGE
north west LA
I would also recomend the scat I-beam rods if you are trying to keep costs down
[Re: emarine01]
#348294
06/16/09 11:51 AM
06/16/09 11:51 AM
Posts: 3,635 Oakland, MI
dizuster
Oakland, MI
Even though stroker rmps are lower the piston speed is way up there and puts more strain on the rods,
Piston speed is driven by RPM.
3.58" stroke at 6700RPM = 4000 Feet per min.
4" stroke at 6,000 RPM = 4000 Feet Per min.
Rod doesn't know any difference except it gets less cycles at the same speed. Also, the piston is lighter in a stroker motor (pin's up higher), so it will actually end up with less strain on the rod.
Nobody would question 6,700 in a 360, so why does everyone worry about 6,000 in a 408"
The head will choke and be done making power at the same piston speed regardless of RPM.
340 and 360 rods are different. As I remember 340 are full floating, and 360 are press fit...
(someone feel free to correct me if I have those backwards)
[Re: patrick]
#348297
06/16/09 01:17 PM
06/16/09 01:17 PM
Posts: 11,711 Portage,michigan
B3422W5
Portage,michigan
the Eagle SIR rods are about the only rod i WOULDNT use in a stroker build thats going to make any steam at all, other than the stock rods.Those and the stock rods i would stay away from for sure.
As others have said, put a good rod in it
69 Dart GTS A4 Silver All steel, flat factory hood, 3360race weight 418 BPE factory replacement headed stroker, 565 lift solid cam Best so far, 10.40 @127 1/4 1.41 best 60 foot 6.60 at 103.90 1/8
[Re: dirt]
#348299
06/16/09 03:24 PM
06/16/09 03:24 PM
Posts: 12,419 Kalispell Mt.
HotRodDave
Kalispell Mt.
If you run stock rods you will need to externally balance it or buy expensive mallory to internally balance it. I would buy the SCAT I beam rods also because they are so much lighter it will make your engine rev way easier and be easier on the crank. The lighter weight also helps get you engine to the power produceing part of the rpm range quicker. For around $300 they are well worth the money. I have a set in my 318 along with some light weight pistons and WOW does it rev up quick! I even have a stock cam and heads on it.
[Re: dirt]
#348301
06/16/09 03:29 PM
06/16/09 03:29 PM
Posts: 1,178 Indy
FlyFish
Indy
I just don't think this is a wise place to cut corners and pinch pennies. Scat I-beams are $270 on ebay for a 4340 steel rod...and no I'm not a salesman for them, they are just a heck of a deal for a quality rod (I put a set in my current engine). If you must go with the stock rod, at least get a good light weight piston to give the rods a better chance of living a long life…but those pistons aren’t cheap.
[Re: FlyFish]
#348302
06/16/09 03:39 PM
06/16/09 03:39 PM
HotRodDave
Kalispell Mt.
I also had a set in my 4 inch stroke 318 and they needed ZERO grinding the block to fit, during assembly I tried a stock rod to see and it would have needed a lot of grinding.
[Re: HotRodDave]
#348303
06/16/09 04:32 PM
06/16/09 04:32 PM
patrick
Grand Haven, MI
AFAIK, 340's and 360's use the same basic forging, but the 340's were bushed for a floating pin from the factory, 360's were pressed pin.
if it's going to be a pretty mild street motor, nothing revved to the moon, I wouldn't have a problem using stockers that have been redone. the only issues I can see would be these:
1) you'll most likely need to grind the block a lot more using them w/a 4" crank vs. say, the SCAT I beams (hotroddave didn't have to grind the block at all for the SCAT's).
2) balancing, the heavier rods might make it more expensive to internal balance, or you'll have to balance it externally to 360 specs, not a big deal if it's not being revved to the moon IMHO (Don, B3422W5 ran his old motor for what, 3 seasons running 10.70's externally balanced, and to 7K rpm without issue)
3) if they're currently pressed pin, finding a reasonable cost piston for pressed pin app to work with the closed chambered eddies. looks like the KB745 is your best bet. otherwise you need to bush the small end, adding to the cost.
4) the KB's need the small end narrowed to 1" (magnum rod width, also what most aftermarket rods are, since they're based off of a 6.125" SBC forging). that additional machining will add to the cost, or it will drive you to more expensive options (SRP, Diamond, etc)
I guess it all depends on how much time (block grinding) vs. ability to do yourself (do you have access to a mill?) vs. money you want to spend. cheapest and easiest might be to buy one piston and just fix your stock stroke motor.
[Re: emarine01]
#348306
06/17/09 11:43 AM
06/17/09 11:43 AM
dizuster
Oakland, MI
At face value it all sounds right but there are other factors that come to play , the starting and stoping forces are greater as the dwell time at the top and bottom of the stroke change and the rod angle changes with the longer stroke, some say it makes no diff and others say it does ,Thats why the better rod is worth the bucks cause I think nobody knows for sure
That's true, but if you do the calculation the tensile g-forces on the 4" crank motor with a 6.123" rod at 6,000 are actually about 12% lower then the 3.58" crank motor with a 6.123" rod at 6700 RPM even though the Average piston speeds are nearly identical.
I was trying to use average piston speed for calculation because it's easier to understand then going through the kinematic calculations for peak acceleration forces.
Here's an online calculator, you can plug in the numbers yourself.
http://www.slowgt.com/Calc2.htm#PistSpeed
I'm not trying to start a war with anyone, but God forbid, what did people do for 30 years before you could buy a $270 set of rods?!
Plenty of w2 360 motors were built with stock rods/ARP combo, and lived to tell about it.
I'm all for buying quality parts where needed, but I also hate to see people spend money just because...
A better question is, who on the board has broke a stock rod, (stroker or not), and under what conditions did it happen? (RPM, HP, Piston weight, etc...)
[Re: emarine01]
#348308
06/18/09 09:31 AM
06/18/09 09:31 AM
Posts: 4,448 Phoenix, AZ
MoparBilly
Phoenix, AZ
Dirt,
My question would be, are you going to save money by buying the pistons and crank seperately, or would it be just as inexpensive to buy a ready to go kit with new rods??
FWIW, I have a 3.79 stroke 340 with stock rods, 6400 shift point, 10.70's in a 3000lb A Body. Well over 500 runs on this motor.
"Livin' in a powder keg and givin' off sparks"
4 Street cars, 5 Race engines
