where to get edelbrock rpm valves #348240
06/15/09 06:22 PM
06/15/09 06:22 PM
ontario canada
mac56 Offline OP
mac56  Offline OP
ontario canada
Does anyone know if eddie rpm valves are available from other sources other than edelbrock?
Re: where to get edelbrock rpm valves [Re: mac56] #348241
06/15/09 06:57 PM
06/15/09 06:57 PM
Affton MO
Q
qwkmopardan Offline
qwkmopardan  Offline
Q
Affton MO
Summit stocks them.
Re: where to get edelbrock rpm valves [Re: qwkmopardan] #348242
06/15/09 07:24 PM
06/15/09 07:24 PM
ontario canada
mac56 Offline OP
mac56  Offline OP
ontario canada
Summit stocks them.
Thanks for the info. I'm in Canada and would like to get the engine back together for the weekend. Would this be the same size stainless valve that would be used in a stock head.
Re: where to get edelbrock rpm valves [Re: mac56] #348243
06/15/09 08:02 PM
06/15/09 08:02 PM
communist bloc of new jersey
jamesc Offline
jamesc  Offline
no they are not the same as stock valves, not even close. here's a link for them at summit
http://www.summitracing.com/search/Part-...lbrock%20valves
Re: where to get edelbrock rpm valves [Re: jamesc] #348244
06/15/09 09:06 PM
06/15/09 09:06 PM
ontario canada
mac56 Offline OP
mac56  Offline OP
ontario canada
Thanks for the link.
Re: where to get edelbrock rpm valves [Re: mac56] #348245
06/15/09 09:12 PM
06/15/09 09:12 PM
Ebrock valves are heavy...If you have to replace them buy some Ferrara's and put in them
Re: where to get edelbrock rpm valves #348246
06/15/09 09:25 PM
06/15/09 09:25 PM
Canton, Ohio
Sport440 Offline
Sport440  Offline
Canton, Ohio
I thought it was determined that the Eddy valves are indeed made by Ferrara. mike
Re: where to get edelbrock rpm valves [Re: Sport440] #348247
06/15/09 09:52 PM
06/15/09 09:52 PM
sc
tjmarcus1 Offline
tjmarcus1  Offline
sc
call mike chenoweth, a member on here aka cre2004
Re: where to get edelbrock rpm valves [Re: Sport440] #348248
06/15/09 10:00 PM
06/15/09 10:00 PM
They may claim them but they are a heavy two-piece
valve that is farmed out to a factory in South America for production...I am speaking of the good stainless race valves Ferrara makes...poppaj
