A body dash wiring ????s #347920
06/15/09 03:56 PM
06/15/09 03:56 PM
Streetsboro ,Ohio
72duster318 Offline OP
Streetsboro ,Ohio
1. Where is the best place to order a new harness.
2. I'm putting a 68/69 rally dash in a 70 Dart, asisde from the ignition being on the dash instead of the column, how much diffence is there, and what should I order for it?
Thanks, John
If you didn't build it yourself, it's not really yours - Tim "the toolman" Taylor
Re: A body dash wiring ????s [Re: 72duster318] #347921
06/16/09 06:48 PM
06/16/09 06:48 PM
Streetsboro ,Ohio
Streetsboro ,Ohio
I can't believe NOBODY has made this swap and can give a little insight.
Re: A body dash wiring ????s [Re: 72duster318] #347922
06/16/09 07:56 PM
06/16/09 07:56 PM
Ste-Sophie, Quebec, Canada
W
Wedgeman Offline
Wedgeman  Offline
W
May be if you just switch the gauges wires to the round connecter of the rallye will do ?
Dan
Re: A body dash wiring ????s [Re: 72duster318] #347923
06/16/09 08:33 PM
06/16/09 08:33 PM
My Duster has a 69 Barracuda harness in a 71 Duster rally dash. I cut a hole and mounted key in pre-70 location. I did this because I had a 69 formula S parts car and it was the only manual steering column I had. This was back in early 90's and everything still works. I wish we talked at BEA about this.
