Carter electric fuel pump P4600hp #347891
06/15/09 01:53 PM
06/15/09 01:53 PM
Woodinville, WA
Viol8r Offline OP
Viol8r  Offline OP
Woodinville, WA
http://www.summitracing.com/parts/CRT-P4600HP/?image=large
This will be a for a 10:1 90%Street/10%strip 440. I would like to try not to run a regulator. Any reason this would not work? I have heard good things about these, fairly quiet and good value.
Its between this and a Mallory 110....opinions?
Thanks,
Re: Carter electric fuel pump P4600hp [Re: Viol8r] #347892
06/15/09 02:09 PM
06/15/09 02:09 PM
A Banana Republic near you.
JohnRR Offline
JohnRR  Offline
I run the carter 4601 HP , they CLAIM 18psi max , using it on my diesel truck , it's only putting out 10 I need the 18
Re: Carter electric fuel pump P4600hp [Re: Viol8r] #347893
06/15/09 10:19 PM
06/15/09 10:19 PM
Stuart FL
mercman1 Offline
mercman1  Offline
Stuart FL
No Problems and quiet. Ran one for years on my 69 GTX with a 440 til I hit 11.70s. When I went the stroker 493 I updated to a Comp 140 with a regulator. The cars is now running 10.80s. Good choice!
