3.0 V6 A/C BELT #347601
06/15/09 08:08 AM
06/15/09 08:08 AM
Warminster, Pa.
Slant69 Offline OP
Slant69  Offline OP
Warminster, Pa.
I have a 92 LeBaron 3.0 V6, Anyone know how to remove the A/C belt? The manual was unclear on this. I saw the idler pulley and turned the bolt on top but pulley didn't move. Is there another bolt to loosen?
Re: 3.0 V6 A/C BELT [Re: Slant69] #347602
06/15/09 11:03 AM
06/15/09 11:03 AM
Grand Prairie,Texas
stumpy Offline
stumpy  Offline
Grand Prairie,Texas
Looks like you loosen the bolt in the center of the pulley and then loosen the bolt on the top that points down. That bolt is the one that thightens the belt.
Re: 3.0 V6 A/C BELT [Re: stumpy] #347603
06/15/09 06:18 PM
06/15/09 06:18 PM
S.E. Florida, USA
rrunner Offline
rrunner  Offline
S.E. Florida, USA
BINGO! With any luck you didn't damage the adjusting bolt as they can bend or strip pretty easy when the pulley nut is still tight.
