Re: 440 six pack question
[Re: Rob440Magnum]
#347555
06/15/09 09:43 AM
06/15/09 09:43 AM
Posts: 3,905 Minnesota
3twos
Minnesota
Do you drive your car in cold weather? If not you probably don't need a choke and can wire it fully open.
Al & Sheila
[Re: 72roadrunnergtx]
#347556
06/15/09 09:43 AM
06/15/09 09:43 AM
Posts: 75,070 U.S.S.A.
JohnRR
U.S.S.A.
This may be the thread mentioned above.
That's it , that REALLY needs to go in the ARCHIVE .
[Re: Rob440Magnum]
#347557
06/15/09 03:07 PM
06/15/09 03:07 PM
Posts: 1,139 West Tennessee
rbstroker
West Tennessee
Although it is harder to keep running when cold, mine is wide open. The carbs are basically stock from my 1970 cuda. Normally I don't drive it when the temp is below 70 though.
This is the land of the free
because of the brave
[Re: DPelletier]
#347559
06/15/09 04:32 PM
06/15/09 04:32 PM
Posts: 765 Shoreline, Washington
72roadrunnergtx
A quick follow-on about this choke mod, I have about 1800 miles on this six-pack motor now without manifold crossover heat and a fully functional automatic choke. A couple pumps on the accelerator prior to crank, it fires up cold and goes directly to a fast idle of about 1400-1500 rpm’s for about 4-5mins. It can be driven right away without hesitation on acceleration or power valve blowing lean back fires.
#347560
06/15/09 06:12 PM
06/15/09 06:12 PM
Posts: 533 Williamsport, PA
Rob440Magnum
mopar addict
mopar addict
Williamsport, PA
So you have a valley pan with the heat crossover blocked off and you also do not have a heat riser correct? Is it possible your choke does not come off completely once the engine is fully warm?
My buddy has a six pack on his 440, he does not have the heat riser but he does have the valley pan tray with the heat crossover NOT blocked off and his car runs great cold but the only thing I have noticed is his motor runs much hotter then my 440 4 bbl. I don't know if the two are related, I always thought his ran hotter because I have a new 4 core 26" radiator and he has a new cheaper 26" radiator.
Any thoughts?
[Re: Rob440Magnum]
#347561
06/15/09 06:20 PM
06/15/09 06:20 PM
Posts: 1,294 Ontario, Canada
FJ5_Fish
Ontario, Canada
I do not have the heat riser. I have a 440 4 bbl currently with the valley tray that has the heat crossover blocked off and my 4 bbl uses an electronic choke.
If I put a six pack on my motor, how will the choke work? Do I need to get a new valley tray so as to not have heat crossover blocked off?
Please explain?
Thanks, Rob
You should get a new valley tray no matter what you do to make sure it seals the new intake. I run factory chokes on all my stuff. I leave the heat riser on (outside - for looks) but cut the flapper off the shaft. The choke still works fine. If you are trying to run the thing in 40 degree weather or less it will just take a few minutes longer to work properly. I cut the flapper off because I had a stuck one once which burned a valve.
[Re: FJ5_Fish]
#347562
06/15/09 06:42 PM
06/15/09 06:42 PM
Rob440Magnum
mopar addict
mopar addict
Williamsport, PA
Should the new valley try have the heat crossover blocked off or not blocked off?
Thanks, Rob
[Re: Rob440Magnum]
#347563
06/18/09 12:47 AM
06/18/09 12:47 AM
72roadrunnergtx
Hello Rob, First be sure to read through my postings on the choke mod thread referenced above. It became rather detailed on why I needed the mod. In my case, I’m running Edelbrock Performer RPM heads which don’t have cross-over passages at all, also running headers (no heat riser). Remember the only reason for the cross-over and heat riser was is to attain acceptable drivability during warm-up. Not really a big concern for most of us today. The divorced choke system used on these cars originally depended on the cross-over heat for correct function/timing. A correctly functioning choke spring will never relax completely when the cross-over is blocked unless it is electrically heated. The heat riser flap/valve was designed to divert passenger side exhaust gases almost completely through the cross-over when first started to improve cold running drivability and relax the choke sooner. The bi-metal clock spring on the riser flap would relax as engine reached operating temperature. By mid seventy’s choke heaters/timers were used entirely and heat riser flaps/valves were omitted all together. I have run many daily drivers back in the day without risers (headers), with open crossovers and had acceptable choke function with slight adjustments. If you block the crossover you will either have to disable the choke or figure out a way to heat it. You will find many opinions here on moparts as to why you would even need a choke at all. The fact of the matter is, in a basically stock configuration and correctly tuned for street use at operating temp, these things will be very cold blooded without a functional choke system. Hope this helps. Good Luck, Doug
