True stock 400 piston compression height? #347432
06/15/09 12:58 AM
06/15/09 12:58 AM
California
P
polkat Offline OP
mopar addict
polkat  Offline OP
mopar addict
P
California
I keep reading that it's 1.812" but my measurements are 1.832" Am I measuring this wrong?
Re: True stock 400 piston compression height? [Re: polkat] #347433
06/15/09 01:01 AM
06/15/09 01:01 AM
Carstairs, Alberta, Canada
dave571 Offline
dave571  Offline
I'm not sure about that number.
I do know that the 400 I built for my van, which was a 76 I think, they were .100 to .130 in the hole(yes that much varience)
Hope this is of some help.
Re: True stock 400 piston compression height? [Re: polkat] #347434
06/15/09 01:17 AM
06/15/09 01:17 AM
put the piston upside down on your table w the flat side down with it slightly off the edge so you can measure it & slide the pin out about an inch & with your 2"-3" mike measure from the bottom of the pin(the top now) to the deck & subtract 1/2 of the pin dia and be aware some KB pistons have a slight quench pad ~.035" or so that is not included in the CH dimention and you would measure to the flat adjacent to that pad.
Re: True stock 400 piston compression height? [Re: RapidRobert] #347435
06/15/09 05:19 AM
06/15/09 05:19 AM
the frozen wastes...
Pale_Roader Offline
Swears too much
Pale_Roader  Offline
Swears too much
I've measured a couple o mine recently, and i get .100 to .110 in the hole across the board. Guess i'm lucky, they can really be all over the chart. I'd say those are easily possible numbers.
Just once i'd like to break open a 400 and find some nice KB or forged zero-deck pistons...
Re: True stock 400 piston compression height? [Re: polkat] #347436
06/15/09 09:33 AM
06/15/09 09:33 AM
A Banana Republic near you.
JohnRR Offline
JohnRR  Offline
1.832 would have the piston about .103 in the hole at TDC on a blueprint spec block, what are you getting ? A true ZERO deck piston on blueprint 9.980 would be 1.935 .
Re: True stock 400 piston compression height? [Re: polkat] #347437
06/16/09 12:05 AM
06/16/09 12:05 AM
Canton, Ohio
Sport440 Offline
Sport440  Offline
Canton, Ohio
My pistons from two seperate stock 400 engines measure a CH of 1.8315 to 1.8320" mike
Re: True stock 400 piston compression height? [Re: Sport440] #347438
06/16/09 02:27 AM
06/16/09 02:27 AM
California
P
polkat Offline OP
mopar addict
polkat  Offline OP
mopar addict
P
California
Well, guess my measurements were right.
Re: True stock 400 piston compression height? [Re: polkat] #347439
06/16/09 08:39 AM
06/16/09 08:39 AM
JohnRR Offline
JohnRR  Offline
Where are you READING this ???
