How Can You Tell If A Cam Lobe Is Wasted? #347204
06/14/09 11:03 PM
06/14/09 11:03 PM
NE Ohio
71 FJ6 Charger Offline OP
NE Ohio
I have a 383 I am replacing all the gaskets on,figure I would find out what to look for,if anything as far as cam lobes being wiped out. Everything else checks out OK. Its apart so I thought I would ask now. Thanks all.
'71 383HP FJ6 Charger SE
Re: How Can You Tell If A Cam Lobe Is Wasted? [Re: 71 FJ6 Charger] #347205
06/14/09 11:11 PM
06/14/09 11:11 PM
qc
mxbeep Offline
mxbeep  Offline
qc
Assuming your valve covers are removed:
Start by removing rockers and shafts,
remove lifters one at a time and check bottom for wear.
You will need a long magnet to remove and install lifters.
Re: How Can You Tell If A Cam Lobe Is Wasted? [Re: 71 FJ6 Charger] #347206
06/14/09 11:14 PM
06/14/09 11:14 PM
Someplace you aren't
SomeCarGuy Offline
SomeCarGuy  Offline
Put a new chain in there while you are at it.
Re: How Can You Tell If A Cam Lobe Is Wasted? [Re: SomeCarGuy] #347207
06/14/09 11:27 PM
06/14/09 11:27 PM
IA
landon1 Offline
landon1  Offline
IA
i've heard that weak cams or oil-starved cams can go "round"....this is what happened to the intake lifter on the number 1 cylinder of my 440....
'71 Satellite Sebring 440
Re: How Can You Tell If A Cam Lobe Is Wasted? [Re: landon1] #347208
06/15/09 07:51 AM
06/15/09 07:51 AM
Columbia, CT
moper Offline
moper  Offline
Columbia, CT
The best way is to visually inspect each lobe whiel it's apart. If you dont think it looks good, post a pic...
Re: How Can You Tell If A Cam Lobe Is Wasted? [Re: moper] #347209
06/15/09 08:50 AM
06/15/09 08:50 AM
Use a dial indicator or other measuring device "in the car" to measure lift, most accurate at the lifters.
If the cam is out just caliper them. You'll have to visually ID the intake from the exhaust, because they'll be different
Lifter condition is a fairly good indicator. If the lifters all show similar wear patterns, chances of one flat lobe are slim
I'm a BIG believer in keeping old lifters with the original lobe, so if you remove the cam and re-use it, lay out the lifters in order
Re: How Can You Tell If A Cam Lobe Is Wasted? #347210
06/15/09 09:40 AM
06/15/09 09:40 AM
NE Ohio
NE Ohio
Awesome responses and pics thanks. Gonna start pullin lifters here in a few. I'm feelin lazy,I'll have to think about the pics.........
Re: How Can You Tell If A Cam Lobe Is Wasted? [Re: 71 FJ6 Charger] #347211
06/15/09 10:23 AM
06/15/09 10:23 AM
BROOK PARK, OH
WILD BILL Offline
WILD BILL  Offline
BROOK PARK, OH
Do you have a cam card for it?
Re: How Can You Tell If A Cam Lobe Is Wasted? [Re: landon1] #347212
06/15/09 10:36 AM
06/15/09 10:36 AM
Indy
FlyFish Offline
FlyFish  Offline
Indy
That was close!! Mine had a hole in the bottom of the lifter after it failed...probably another minute in the motor and yours would have looked the same.
67 Barracuda street car, 408, e85, 1.38 60', 6.44 @105.9 in the 1/8 mile, 10.19 @130.5 in the 1/4...so far....
Re: How Can You Tell If A Cam Lobe Is Wasted? [Re: FlyFish] #347213
06/15/09 10:38 AM
06/15/09 10:38 AM
Virginia
HemiStan Offline
HemiStan  Offline
Virginia
Here is a picture of a lobe on one of my cams that I found a couple of weeks ago.
Stan
Re: How Can You Tell If A Cam Lobe Is Wasted? [Re: WILD BILL] #347214
06/15/09 11:05 AM
06/15/09 11:05 AM
NE Ohio
NE Ohio
WILD BILL,wuzz up!! No card,virgin 71 383HP motor,stock cam.
If all checks out good I'm gonna degree it once I get a new chain for it.Gonna pull some lifters here soon and compare to some pics the guys put up for me(thanks!). I'm still gonna hold ya to that trans rebuild!
Re: How Can You Tell If A Cam Lobe Is Wasted? [Re: HemiStan] #347215
06/15/09 11:06 AM
06/15/09 11:06 AM
NE Ohio
NE Ohio
Stan
Thats too bad,looks like it was a fairly fresh motor.That sux.
Re: How Can You Tell If A Cam Lobe Is Wasted? [Re: 71 FJ6 Charger] #347216
06/15/09 01:58 PM
06/15/09 01:58 PM
NE Ohio
NE Ohio
OK,I pulled a few lifters,and they have some wear,but NOTHING like the pic of the above lifter. It just has a slight concave to it,but dont look burnt,and its not as deep as the one pictured above. Is this normal wear? Should they be replaced? The lobes also look all about the same. Nothing like the lobe pictured here above.
Re: How Can You Tell If A Cam Lobe Is Wasted? [Re: 71 FJ6 Charger] #347217
06/15/09 02:06 PM
06/15/09 02:06 PM
So Cal
HealthServices Offline
Why would you even post that?
So Cal
I recommend replacing the cam and lifters if you have any concave lifters. They should all be convex when you put a straight edge on them. A little extra money here will save you a lot of money later.
Convex lifters rotate. Concave do not. This is what kills cams and lifters. If the lifter is slightly concave now, expect it to go bad in the future! This can be in 500 milies or 5000 miles but it will happen.
Sometimes you can get away with just replacing the lifter but just make sure the cam lobe is good by using a dial indicator to check lift and compare it to the others. This is preceded by a visual check for cam wear.
Re: How Can You Tell If A Cam Lobe Is Wasted? [Re: HealthServices] #347218
06/15/09 03:07 PM
06/15/09 03:07 PM
BROOK PARK, OH
WILD BILL Offline
WILD BILL  Offline
BROOK PARK, OH
I don't know how you would degree the cam without having the card. All you could do at this point is use a dial indicator to look for differences in lobe lift of all the lobes. Compare intake to intake and exuasht to exuahst. The intake and exhaust lifts could be different.
Re: How Can You Tell If A Cam Lobe Is Wasted? [Re: WILD BILL] #347219
06/15/09 04:43 PM
06/15/09 04:43 PM
NE Ohio
NE Ohio
I dont have a card,but I do have the factory specs on the cams. The same as a card I would think.
Re: How Can You Tell If A Cam Lobe Is Wasted? [Re: 71 FJ6 Charger] #347220
06/15/09 05:46 PM
06/15/09 05:46 PM
Chino Valley
RodStRace Offline
RodStRace  Offline
Chino Valley
Here's a shade tree way to check the lifter surface. Remember, keep them in order!
Take one lifter and hold it horizontal. The bore surface is as flat as you can get, since these are not tapered on the sides.
Touch the base of a suspect lifter to the side of the horizontal lifter, trying to contact the highest edge evenly. It should have a very slight bit of light between each edge while touching in the middle. If not, it could be worn. If there is light in the middle, it's time for new lifters!
Re: How Can You Tell If A Cam Lobe Is Wasted? [Re: RodStRace] #347221
06/15/09 06:28 PM
06/15/09 06:28 PM
NE Ohio
NE Ohio
My buddy I just talked to has a set he's gonna give me. He just used them to break a cam in before he went to a different lifter set. The break in was successful so that is what I'll be using. Can't beat free! Thanks guys
Re: How Can You Tell If A Cam Lobe Is Wasted? [Re: 71 FJ6 Charger] #347222
06/16/09 07:18 AM
06/16/09 07:18 AM
Grand Haven, MI
patrick Offline
patrick  Offline
Grand Haven, MI
can't reuse used lifters on a different cam, they are broken in to that specific cam.
2017 Grand Cherokee Overland
Re: How Can You Tell If A Cam Lobe Is Wasted? [Re: patrick] #347223
06/16/09 09:23 AM
06/16/09 09:23 AM
NE Ohio
NE Ohio
Done it 100 times through the years,it'll be fine.
It's not a race motor,wont hurt anything.
As long as I treat it like a fresh cam and lifters,they'll wear in to this cam just fine.
